Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
taking off heads...
Old Mar 16, 2007 | 05:44 PM
DSRCAM's Avatar
Default taking off heads...
i plan on taking off my 806 heads does anyone have any recommendations on what tools i need to take em off..
Old Mar 16, 2007 | 05:48 PM
Cop Car's Avatar
my suggestion is to remove the motor out the bottom, do your head, cam swap, rod bolt upgrade with the motor out of the car.
Old Mar 16, 2007 | 05:49 PM
DSRCAM's Avatar
no to bad of an idea man thanks but how to i pull the motor oout of the bottom if i dont have a lift??
Old Mar 16, 2007 | 10:41 PM
marv's Avatar
Man, if you're just doing heads, don't bother with pulling the motor out of the car...it's too easy to just do them in the car...
You're normal hand tools will enable you to accomplish practically all the job...only special tool I can think of off the top of my head is a fuel line release tool. You can find them at any good autoparts store...
Make sure you have a good assortment of wrenches and extensions as well...
Old Mar 16, 2007 | 11:32 PM
DSRCAM's Avatar
thanks marv i pretty much took off everything now i just need a fuel line release tool and now i the hard part is tommorrow!!
Old Mar 17, 2007 | 02:24 AM
sidewayz28's Avatar
extensions..
Old Mar 17, 2007 | 04:57 PM
Cop Car's Avatar
you hook the body to the cherry picker instead of the motor
Old Mar 17, 2007 | 05:11 PM
1320 killer's Avatar
Here is a complete step by step on a heads and cam swap for the f-bodies
http://www.ls1howto.com/index.php?article=2
Old Mar 17, 2007 | 05:18 PM
Ls1Bait's Avatar
Tourqe wrench, And basic hand tools. Take your time and clean everything along the way.
Old Mar 17, 2007 | 05:22 PM
NoGamesLS1's Avatar
...Or just pull it out the top
Old Mar 17, 2007 | 06:56 PM
davered00ss's Avatar
Moderator
Basic hand tools and a TQ wrench. Probably want an air compressor to blow out the bolt holes before you put the new ones in. Also a Small shop vac to put on the water pump and suck out the coolant helps out. Less mess. 4 hr job with the motor in the car.
Old Mar 20, 2007 | 12:21 PM
Cop Car's Avatar
why, its easier to go out the bottom. takes the same ammount of time to take it out as to do it from the top, but i had my motor back into the car in 10 minutes with every wire connector hooked up and headers on the car. cant do that out the top.
Old Mar 20, 2007 | 12:25 PM
brad8266's Avatar
Very easy to drop it out the bottom and it gives you all the room you need to work on the engine and to be detailed enough for cleaning decks and holes out.
Old Mar 20, 2007 | 01:11 PM
blkbird's Avatar
A big breaker bar wouldnt hurt...
Old Mar 20, 2007 | 09:02 PM
WILWAXU's Avatar
You don't need to pull the motor to change heads. Do it in the car.
Old Mar 23, 2007 | 10:41 PM
Shinigami2x4's Avatar
No need to take the motor out for the heads and wouldnt hooking the cherry picker up to the body scratch the paint, dont see a good hook point for it. maybe i overlooked it
