Dynojet 224 for sale
Dynojet model 224 inground. Comes with:
Available as a pit model or used above ground with a 4-post lift
Measures up to 1500 + hp and 200mph
Dynamometer Chassis (drums, shaft, bearings, etc.)
WinPEP7 Software and Hardware to interface (PC, printer, etc. not included)
Auto Tie Down Package (straps, ratchets and hooks)
Ignition Wire Inductive Tachometer Pickup Leads
Anchor Bolts with Level Adjusters
Four Rubber Chocks
Air Actuated Brake System
Remote Software and Brake Control From Driver's Seat
Automatic Conditions Measurement (absolute pressure, air temp, etc.)
Also including:
Pit Covers
Wideband Air/Fuel
Optical RPM Pick-up
PC, Monitor, Printer.
This is everything to make the dyno operational. It was only used 30 times at a max. of 800hp.
All dyno electronics have been replaced.
Dyno located just north of Chicago, IL.
Contact info:
Brandon, Owner
Midwest Performance
(815)276-3943
Asking $20,000
Four Rubber Chocks
Also including:
Pit Covers
Wideband Air/Fuel
Optical RPM Pick-up
Contact info:
Brandon, Owner
Midwest Performance
(815)276-3943
Asking $20,000
Four Rubber Chocks
Also including:
Pit Covers
Wideband Air/Fuel
Optical RPM Pick-up
Contact info:
Brandon, Owner
Midwest Performance
(815)276-3943
Asking $20,000
Four Rubber Chocks
Also including:
Pit Covers
Wideband Air/Fuel
Optical RPM Pick-up
Contact info:
Brandon, Owner
Midwest Performance
(815)276-3943
Asking $20,000
