Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Welding SS tubing
Old 03-20-2007 | 01:19 PM
Phil99vette's Avatar
7 Second Club
Default Welding SS tubing
Do you need to shield the inside of the pipe or is there a way to weld it without shielding inside?
Phil
Old 03-20-2007 | 02:27 PM
jdustu's Avatar
Phil
if you don't shield it you will get corosion from the inside.....you can use a chill ring and i don't believe you need to shield(with gas) it then because it blocks the atmosphere from getting to the weld...i'm sure someone here has more ss pipe welding experience than me, but i do know that some type of shielding to block exposure to air is required to keep the backside from corroding....
Old 03-20-2007 | 02:45 PM
wkdivr's Avatar
You usually purge it with Argon. Block, or tape one end shut. Tape the other end, then make a slit with a razor blade in it for your purge line. Keep the purge on the entire time you're welding, and a few minuites after.
Old 03-20-2007 | 03:57 PM
DC@CSC's Avatar
There is a product called Solar Flux you can pick up at a welding supply shop. It takes the place of back purging the SS that your welding. I've never used the stuff before but it suppose to work.
Old 03-20-2007 | 09:08 PM
jdustu's Avatar
heres a good article comparing flux coated rod, backing flux and back purging..
http://www.sperkoengineering.com/html/Purge.pdf
Old 03-21-2007 | 10:52 AM
abustiffy's Avatar
I just setup a backpurge with about $10 worth of components from ace. Works great.
Old 03-23-2007 | 07:31 PM
AMSwill's Avatar
the only time we ever use back purging at the shop i work at is if the part is a high stress component like a thin wall turbo header. on our production turbo kit header...which is thick wall...we have never back purged and have not had an issue. im not saying that it is a bad idea by any means but IMO it would depend on what your doing
Quick Reply: Welding SS tubing
