Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
getting oil out of concrete
Old May 16, 2007 | 07:33 PM
THE_SUPRA's Avatar
Default getting oil out of concrete
whats the best solvent/cleaner to get rid of my spill stains in the garage? i have heard WD40 but it does not work to well.
thanks
Old May 16, 2007 | 08:14 PM
mrdragster1970's Avatar
6 & 8 Second Club
gas, becareful.
Old May 16, 2007 | 09:04 PM
THE_SUPRA's Avatar
yes non-polar interactions...i see...yes, yes....
Old May 16, 2007 | 09:19 PM
budhayes3's Avatar
PT's Slowest Truck
I usually use brakleen and some rags...
Old May 16, 2007 | 10:41 PM
xfactor_pitbulls's Avatar
Muriatic acid mixed 50/50 with water for us hardcore dirty guys. Let it soak for 15 minutes and hit with a 30* nozzle on a 3000psi pressure washer. Dont use a less degree tip than that at the higher psi. You will cut into the concrete.
Old May 17, 2007 | 12:11 AM
Formulated's Avatar
There was some stuff I got from my local Do-It Center store. It was citrus based, so it smelled like oranges. You would put this stuff on over the stain, then let it dry, which took about 8 hours. It dried to a powder, then you just swept it up and the spot was gone. It went on sort of thick, but it still pours right out of the bottle.
I can't remember what it was called now, but if you looked around I'm sure you can find it in Home Depot or Lowes.
Old May 17, 2007 | 07:53 AM
Gimp98TNT's Avatar
Oil dry works good, but you have to leave it sitting on the stain for about a week or so. And every couple of days go out and kick the pile around a little
Old May 17, 2007 | 02:01 PM
Oso SS's Avatar
paint thinner or brake cleaner?
Old May 19, 2007 | 01:27 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
Brake cleaner will work allright. But will probably also stain.
Best thing to do is head to Pep Boys, and get some "Purple Power". It's their generic degreaser/cleaner.
Works awesome, that's what we use at the shop. Just dump some on the floor, and spray some water over it. Grab a push broom and work the floor. Now just squeegee it out.
Old May 19, 2007 | 06:56 PM
ONEBADASSWS6's Avatar
Purple Power works very well. Castrol Super Clean is also great stuff, cleans just about anything without using acid or other environmentally toxic materials.
I wouldn't touch Muriatic acid, I could only see using it as a last resort. That stuff is very dangerous and toxic, not worth it to get a stupid stain off the floor.
Old May 20, 2007 | 10:10 PM
budhayes3's Avatar
PT's Slowest Truck
I'm gonna have to look into that Purple Power...sounds good
Old May 21, 2007 | 12:09 PM
slvr98camaro's Avatar
i saw a product at the hardware store the other day, you pour it on an oil stain, and leave it there.. it then absorbs the oil, then turns into a powder that you can sweep away.
not sure how well it works, but i almost bought it.
i usually use lestoil and powder soap to clean up oil stains
Old May 21, 2007 | 12:20 PM
xBROKEx's Avatar
ill take a pic of what i have at home later, i got it from home depot and it worked great, i tried that powder stuff but it doesnt get the deep stains out.
Old May 21, 2007 | 10:19 PM
BigJls1's Avatar
I'm with pitbull, there are very very few non toxic cleaners that work worth a darn. Muriatic acid is not like it will eat your hand off as soon as you touch it . be carefull with it and use alot of water to dilute it into the gutter, it will actualy help clean out your steets drain pipes.
