purchase a tig or powerful mig?
My bigger bitch about them is that their wire feed sucks, it’s like some rube Goldberg contraption involving springs, washers, wing nuts and half a box of odd hardware that was designed to torture the user. I welded in a roll cage with one borrowed from a friend, and it took me two whole days, one that finally turned into figuring out/fixing the wire feed all day, and a second building the cage.
my machine has the same problem with the wire feeding. it only likes to feed the 10 lb spools or its gets stuck
They still sell the SP135 and 175, those are the old machines, but the new, Powermig 140 and 180 are VERY nice for machines in that class and still in the same price range. I know someone t hat has never had anything but millers in his production shop that was so impressed by their new little MIGs that he bought 2 power mig 140’s for the shop the first week they were out. So the answer to your question: well, getting a PowerMig180 will not technically give you any capability that you don’t have now real world, it will give you a MUCH nicer machine that shouldn’t be as frustrating to use with probably 2x the duty cycle (which again, you shouldn’t be running into anyway if things were working right). I love my HH135, but I’ve seriously considered snagging one of the power migs anyway (probably a 180, not so much for the “bigger power” but because I wired all the 240V circuits in the house and I have much better 240V supply in the garage than 120…).
If there’s a bigger local welding supply in your area you might want to stop in, they’ll usually let you play with the machines before buying. I usually stick with one of the smaller ones, but the owner there _really_ knows his **** and has never steered me wrong and always gives me the best deals (they’ve become quite popular on the ‘net and ebay, B&R Welder…)
just the subpanel install with plugs and such is going to run around 200-300 so i decided to not run a dedicated line as of yet. i looked at the need for the lincoln 175 and saw that it used 21 amps, whereas the power mig 180 used 20 amps. do you think i would get any benefit from using a bigger machine such as this? or should my upgraded electric help me out? i know my 135+ trips my 20amp breakers, but the receptacle is tapped off the microwave in the kitchen and i doubt the wiring is any good.
They are great for wrought iron. I would never use it for anything with structure involved. Ok really they work good for body repairs, exhaust, gates and fixin the patio chairs. 220 will do all that plus more. If you spend 600$ on a good 110 for a little more like 800 or 900 you can get a real welder.......... 220.
It all really depends on what knid of work you're mostly going to do. A MIG is usually well suited to the kind of work you mentioned originally. I can't imagine using my Miller Synchrowave to build a trailer. For an occasional need to weld aluminum or stainless, you could always go to a professional welder. I use my TIG a lot for finely controlled work, but it does have its limitations.
Andy1
I love all the people that "flash" all their knowledge just to fill space and not give info for the topic at hand
Jimmy
