Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Must haves for fabricating????
Old Aug 20, 2007 | 08:40 PM
B18CYA's Avatar
Default Must haves for fabricating????
Going to start my turbo kit and need to make sure I have every thing I need. I already have:
Air grinder and cut off tool
chop saw
sawzal
mig welder
4" grinder
bench grider
What do you guys use when cutting exhaust to grind it straight?
Old Aug 21, 2007 | 06:13 PM
CTSmechanic's Avatar
TIG welder... for stainless
Belt sander
Die grinder with barrel sander arbor
Old Aug 21, 2007 | 10:33 PM
bgblockelcamino's Avatar
i use the chop saw to clean the pipes up on the bends and making them straight. i use air grinder to debur
i tack with mig then finish everything with TIG
Old Aug 28, 2007 | 07:08 PM
AMSwill's Avatar
if you can get your hands on a band saw that would help i would say.
Old Aug 29, 2007 | 01:37 AM
ace68's Avatar
why do you need a tig for stainless?
Old Sep 18, 2007 | 10:23 PM
fabricatorx's Avatar
Welders, MIG and TIG
Angle grinders, many with each possible wheel combo.
Chop Saw
Belt sander
...and a few miscellaneous secret tools
Old Sep 18, 2007 | 10:39 PM
Rota broach kits...
Smart level
unibits
tilman trufit gloves...
squares...
eventually you get to where you get enough air tools so you dont have to switch arbors...
30 or so different types of vice grips....
It just depends on the amount of money you want to invest the right quality tools makes the job alot easer and better results...
