Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
New kind of jack?
Old Aug 26, 2007 | 07:38 AM
lovin myls1's Avatar
Default New kind of jack?
Anyone ever seen one of these?Wonder if they work.Tried to Google more info on it,but no luck?It's under a hundred bucks and a pair might be an easy way to get our F-bodys up.
[IMG]
Old Aug 26, 2007 | 07:40 AM
00SS!'s Avatar
Where did you find those?
Old Aug 26, 2007 | 08:13 AM
Harbor frieght.com has then for 79.95 on sale on their website.In their find box type3000 lb. tire lift.
Old Aug 26, 2007 | 08:44 AM
DRIVER456's Avatar
I read awhile back,I think it was some guy from the Corvette forum designed that jack and sent the plans to Harbor Freight and they built them.............Paul
Old Aug 26, 2007 | 10:58 AM
Stopped in at my local Harbor Freight store today.They didn't have one to look at(I'd never seen one there) and it's not in the special order catalog.
It's weird that I can't get any more info on it on the Net.Looks like a good, safe way to raise car but would need two of them!
Old Aug 27, 2007 | 01:36 PM
jmarsa's Avatar
It's here:
http://www.harborfreight.com/cpi/cta...emnumber=95420
--JMarsa
Old Aug 27, 2007 | 02:21 PM
02gtp4now's Avatar
unless its not showing a larger foot on the bottom i would not trust it
Old Aug 27, 2007 | 04:16 PM
camaro-94-z28's Avatar
yea it needs a larger foot
Old Aug 29, 2007 | 04:53 PM
billyb's Avatar
Default new name !!!
Suicide Lift, Used Once ?????
Old Aug 29, 2007 | 06:13 PM
BeemerZ28's Avatar
the upper portion leans against the upper sidewall of the tire( you can read the instruction manual)
in other words not only is it lifting the car but also pushing into it a little bit so as to be more stable. I would say that using two of these would be a no-no. They would become very unstable.
These seem like a good idea but need a much larger foot pad, which would kinda defeat the purpose since you would need to drive onto the foot pad. Even then any forward to back motion of the car and splat your face/body is no more.
Old Aug 29, 2007 | 06:22 PM
Guess it's not a very good idea.By the way,where can you read the instruction manual?
Old Aug 29, 2007 | 10:05 PM
2002ssls1's Avatar
I must be an idiot, but I cant see how that works. Can someone please tell me.
Old Aug 29, 2007 | 10:30 PM
wowsers's Avatar
it says its a jack, not a jack stand. so you would lift it, put a jack stand underneath, and move to the next tire. it looks more stable than the jack were given from the factory
Old Aug 30, 2007 | 12:01 AM
Shock Hawk's Avatar
What part of that jack is gonna fail first? I'd say that the bolts that hold that horizontal piece are going to get sheared off. How to fix this? Move the horizontal piece lower so that there's less torque applied on the bolts.
Old Sep 14, 2007 | 12:12 PM
Demon Of Dreams's Avatar
well, considering harbor freight had it made... I can't imagine getting more than a few uses out of it... I bought a 3 ton floor jack (with a warrany thankfully) from them that failed after about 2 weeks of use took it back, the second one has held up quite a bit more, but still...
Old Sep 14, 2007 | 12:45 PM
98_Formula's Avatar
looks interesting, for everyone saying the stuff about the jack failing and crushing you, i hope, REALLY HOPE, that after you jack up a car, regardless of what jack your using, YOU PUT JACKSTANDS UNDER YOUR CAR. never never never just leave it a jack under your car...
hell i jack up my car, put jackstands under, and then put logs under there, incase the jackstands fail, the wood will leave abou a foot or so of clearance, not comfortable if that ever happened, but not dead either.
Old Sep 14, 2007 | 05:50 PM
"but not dead either" is a VERY good plan!LOL
Old Sep 14, 2007 | 11:47 PM
87formy's Avatar
Ok, this just popped in my head. What if we're looking at this jack all wrong. What if you just put this under the tire of a lowered car to jack it up a little bit. Then, you have the added clearance to get a real jack under the k-member! Sound good?
Old Sep 15, 2007 | 02:40 AM
98_Formula's Avatar
the description sounds more like its just supposed to be a jack, or replace the normal jack. jack it up with this item and then put your jackstands (and option logs) under the car ...
i am not seeing how it is actually standing tho, with that small of a base it looks like it would fall right over...
i'm also not seeing how you would actually jack the car up... would like to see it in person.
as far as using this to get a normal jack underneath the car, just buy a low profile jack.
i picked up an "aluminum racing low profile jack" from harbor freight, its a very nice looking piece, and i can get it under my car no problems and its lowered 2inchs (sportline springs)
it didn't cost much more than this "new" jack, i think it came to 130 with tax.
