lifter dowls for cam swap
if anything I might need to shave it down to look more like a D shape instead of O
working on piecing together the pulley installer also.
I am just buying the crane valve spring tool since its heavy duty and does 2.
also I just pieced together the air hose for the spark plug, I just took the valve out of the hose on my compression tester and the other end hooked right up to my air hose fitting.
then some said they flattened it out some, who knows it will only take 5 more minutes to flat one side if needed with a grinder.
