Welding chromoly
**** knuckles, let's see your work big mouth!
You musta got the same PM I got. He wanted to see my work. Well, I don't have any pictures. My welds are in the field doing work. I have a couple at the bottom of the ocean on a pipeline somewhere, done in Monel flanges and pipe. Lots in the middle east, lots here in the states. Big whoop really. But I don't have a website with pictures so I don't know jack
I didn't even look at his site. I could care less. A lot of decent welders are blow hards. Like I said before...he didn't say anything new, he just said it in an incoherent and arrogant fashion.
The color looks cool, but all it is is the result of the chemicals present on the surface of the weld once it's hit by the atmosphere. Get it above a certain temp and it's just gonna be silver or grey. Yeah, you can pour the heat to thicker stuff and still get some rainbows for sure, and it also depends on material composition. High hard and ss really "light up". So does Titanium, which isn't good, and is the reason you need more than typically gas purge.
But it's not really hard to do on thinner stuff. Just heat control.
This stuff isn't really all that thin, both pieces are 1/8". But they are small, so there isn't much metal to soak up the heat.
http://www.flickr.com/photos/browndogwelding/6518466383/
http://www.flickr.com/photos/browndogwelding/6865977856/
Definitely possible. Although to say "nor would it have been" is a bit of a stretch, considering my first though would have been operator error had my posts not been deleted from this forum before without notice. But I don't get on here much anymore, so perhaps you're correct.
