Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
valve Spring tool pics
Old Jul 3, 2003 | 11:18 AM
383LQ4SS's Avatar
Default valve Spring tool pics
This is the one Brandon made..works like a charm.
Old Jul 3, 2003 | 11:48 AM
CAT3's Avatar
Restricted User
Default Re: valve Spring tool pics
Thanks for the pic, dont have it copywrited do you, no patents pending....good time to hit the welder!
Btw way, what is the ring portion from, anything in particular, other than a ring laying around the shop???
Old Jul 3, 2003 | 01:48 PM
383LQ4SS's Avatar
tool grade steel...your probably going to need to TIG it. Otherwise you may burn up the bearing.
Old Jul 3, 2003 | 01:55 PM
CAT3's Avatar
Restricted User
See thats what I'm talking about. Show me the way and then gime the info too. Thanks.
Old Jul 3, 2003 | 06:26 PM
Screamin_Z's Avatar
man, it would cost NOTHING to make those. and then he could sell them cheaper than 130
Old Jul 4, 2003 | 01:55 AM
383LQ4SS's Avatar
you need a supply of old rockers...buying new ones would be too costly. A few old tools...not to much. But there is a bit of labor. I wouldnt even consider making them unless they went for over $100. Wouldnt be worth the time and effort. Its not like you would be making mass quantities to make up for the small profit.
If anyone wants one just let me know and Ill see what Brandon can do.
This should work for the larger springs also...but I believe we are going to make one specifically for the 1.43-1.46 od springs.
Old Jul 4, 2003 | 11:16 AM
Scalpel's Avatar
I'd like to have one, let me know how much!
Old Jul 4, 2003 | 11:37 AM
SLowETz's Avatar
Very .......I want one.
Old Jul 4, 2003 | 12:06 PM
383LQ4SS's Avatar
If I can get 7 or 8 people that want one we will make some up.
Let me know...Al
Old Jul 4, 2003 | 12:20 PM
383LQ4SS's Avatar
i just spoke to brandon and he will make them for whoever wants them. if less than 5, they will go for $125. if more than 5, we will do it for $100 each.
Old Jul 4, 2003 | 10:54 PM
T/A Medic's Avatar
ill take one for sure
Old Jul 5, 2003 | 03:42 AM
383LQ4SS's Avatar
Screw it...to help out fellow LS1tech guys we will make them for $100 and Ill even ship them to you for free. Brandon is on vacation til next sunday so he cant start on them till then. PM me for detials i guess.
Ill round up the materials and we will try to knock out ten or so the following weekend.
Old Jul 5, 2003 | 05:41 AM
CAT3's Avatar
Restricted User
Hell yeah, I am in on this. I just wasted two, yep two Moore Tools, and I am tired of the aluminum shavings everywhere. Glad your shipping too-ehehehehehe Hawaii. Will PM later for the addie etc..
Thanks.
BTW, where the article on your push system, can you email it to me? Very interested from last time I read it an no one seems to understand the concept.
Old Jul 5, 2003 | 08:03 AM
383LQ4SS's Avatar
Woah! What kind of spring where you using the More tool on? Aluminum shavings? Yeah...I guess I can see that would be a PITA.
Well..I can tell you this design works excellent, no aluminum shavings, and has great acces to the locks..as you can see.
Old Jul 6, 2003 | 01:30 AM
CAT3's Avatar
Restricted User
Stock removal, no problem.
918 install...problem, the ends kept coming off one side or the other of the Ti Retainers, and then sometimes, center itself to far forward or rear, pushed one valve down too far, had to rotate crank to get it back in the guide. Damn POS.
Your looks much easier, nice fulcrum and E-Z access to locks. When we ready to ship??? Next payday is 15th!
Old Jul 6, 2003 | 09:37 AM
Scalpel's Avatar
Thanks.
Yep, the Moore tool's are junk.
Old Jul 6, 2003 | 10:23 AM
383LQ4SS's Avatar
Well...Im gonna locate the materials starting monday. Brandon will be back the following weekend. Then we are going to spend the weekend making as many as we can and just sell them for $100 shipped. So probably around the 21st be ready to send out to those who want them
Old Jul 6, 2003 | 10:37 AM
Dave Carney's Avatar
I'm interested too...one question though, it looks like you have to keep pressure down with one hand on the ratchet and the manuever your retainers and locks into position with the other. Is that correct? Or is there a rest position with the spring compressed?
Old Jul 6, 2003 | 11:47 AM
Scalpel's Avatar
Dave, yes, you have to maintain the pressure on the ratchet to keep it depressed.
Old Jul 7, 2003 | 03:02 AM
CAT3's Avatar
Restricted User
BTW, I believe I will be ordering two of these, we ruined both Moore tools, still useable but I really am uncomfortable with aluminum shavings floating around the engine and tired of fighting the fulcrum point!
Spring change with tools in state of repair, under 2hrs. Cant wait to see how quik w./ two of these bad boys!!!
