fabrication torque arm
im looking to fabricate my own torque arm and im looking for a good place to get some parts i need for it. I will be needing some poly bushings,rod ends, adjuster link, nuts and weld in threaded tube ends. anyone know where i can get all this with decent quality and prices. thanks
QA1 has the spherical bar ends ( called hym joints ) anywhere from 25 to 90 bucks an end depending on sizes and stuff. they also have the threaded bung that you weld into the rod.
check your local 4x4 shop, or just search offroad heim joint on google. thats what I did, ended up building my panhard rod for like $35 out of chromoly. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
oh, and I would recomend spending the money on good heim joints, on one part I built I used QA1's economy ones and they are pretty bad. I can imagine myself replacing them very soon
