Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
finishing inside of shop walls?
Old Feb 3, 2008 | 10:12 PM
00silverz28's Avatar
Default finishing inside of shop walls?
What would be the cheapest route to go in finishing the walls of just rough shop? I don't want to put much into it cause its a older barn I'm turning into a small shop till we build our house and my new shop. Let me know what would be the cheapest.
Old Feb 3, 2008 | 11:23 PM
mrdragster1970's Avatar
6 & 8 Second Club
discontinued panelling can be very cheap. 1/4" wafer board. If you want one step finish, cheap insulation board.
Rolls of plastic will be cheap, if you're just looking for a dirt & dust barrier. Good luck.
Old Feb 5, 2008 | 11:45 AM
Ryan K's Avatar
Pathological Modifier
We framed out the interior of our pole building with 2X4's Insulation and 7/16 OSB.
Turned out pretty good:
Ryan K.
Old Feb 5, 2008 | 12:11 PM
chromeplated500's Avatar
well, im with above about getting some paneling... we found some older roofing steel that we put inside.. i also sprayed some sheetrock with some industrial clearcoat and it was awesome... hard, smooth and overall pretty simple..
Old Feb 5, 2008 | 06:29 PM
98blueSScamaro's Avatar
what year is your hydro stream i had one just like it till i got my allison nice boat and shop
Old Feb 5, 2008 | 06:38 PM
craze4speed's Avatar
we have osb painted gray in our shop to protect the insulation
Old Feb 6, 2008 | 08:36 AM
Ryan K's Avatar
The nice thing about OSB is that its cheap and stronger than drywall.
A 4'x8' sheet of 7/16" OSB is $6-$7.
Ryan
Old Feb 6, 2008 | 08:45 AM
JustAnIlluzion's Avatar
if u have the time, then drywall (4x8 piece costs $6). insulate behind it need be. the time consuming part is the taping and mudding the seams and screw holes, but gives it a finished look when done.
Old Feb 6, 2008 | 09:46 AM
6 & 8 Second Club
Forgot to mention, you can paint some paneling, if it bothers you they are mixed & matched. You can also hang backwards & paint white. Nice & bright.
Discontinued stuff has been as cheap as 1-2 bucks. Not often, but I'm a sucker for sales.
That plastic or thin steel sheets is great stuff. My neighbors have been using it for their ceiling & walls. They also buy when on close outs.
Insulation is well worth it. Drywall is probably the nicest. The weight, labor, material costs add way up. Much easier to use a one step item. Good luck.
Old Feb 6, 2008 | 09:59 AM
WarShrike's Avatar
Be sure to paint it, or at least give it a good priming with something light. It really helps with lighting the shop. I remember when we had our shop without anything, just brown insulation and you could hardly see a thing with the overheads because nothing was reflecting off the walls.
It was a drastic change when the drywall was put up.
Old Feb 6, 2008 | 10:14 AM
mitchntx's Avatar
Metal R-Panel.
Cheap, easy to install, quick to install, needs no maintenance, will not burn ... perfect for a working shop.
Old Feb 6, 2008 | 10:53 AM
I'm probably gonna use 1/4" osb. I can get it for $7 a sheet local. I may check on some thicker when I go to get it. I'm gonna put some kind of plastic behind it to keep the water out. This is just a rough poll barn with cracks between the exterior boards. I've got to get the concrete poured first. I'm not worried what it looks like. Its just a temp. solution for the next couple years. We are gonna build a new house and shop. Thanks for all the suggestions.
Old Feb 8, 2008 | 07:31 PM
silverbullet02's Avatar
T is for Towing not Turbo
That's my stream, it's an '85 Voyager...70.8 GPS so far on a stock 2.4 200...just bolted up a slightly modded '95 200 XRi the other day...send me a pm sometime. What's your Allison run?
Brian.
