Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Storage Lift Recommendation?
Old Mar 20, 2008 | 11:27 AM
JohnnyBs98WS6Rag's Avatar
Default Storage Lift Recommendation?
Buying a new house, wanted one w/ a 4-car garage for all 4 of my vehicles (2 "summer only" cars and 2 "year-round" cars). Found a great deal on a house w/ a 3-car that my wife loves, and we agreed if I was going to "suffer" in a 3-car house it would have to have a garage deep and tall enough to swallow a storage lift so I can store my summer cars stacked in the winter and still not have to scrape windows on my winter beater. Given that, been checking out Eagle lifts and their GLO-70 (7000 lb capacity) appears to be a great deal, it also has optional sliding jacks that'll allow break/wheel work. Just wondering if anyone has a recommendation on a better deal / other manufacturer / or why I should stay away from Eagle lifts.
TIA
Old Mar 23, 2008 | 07:31 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Not sure about the eagle brand lifts, but I went with a Direct Lift, Pro Park 8s. It has quite a few nice features that some of the other cheaper lifts dont have. The runways for example are one peice units instead of having the l-bends welded on. Check out www.Gregsmithequipment.com for other models that are available. They have another model identical to the one I got that goes almost a foot higher in case you wanted to park an SUV or truck under it.
Old Apr 12, 2008 | 06:04 PM
fmowry's Avatar
I also went with the greg smith pro park 8s (and posted about it in The Alchemist's other thread). There is a greg smith in Indiana. I got mine at their Delaware location.
Indianapolis, Indiana
Greg Smith Equipment Sales, Inc.
5800 Massachusetts Avenue
Indianapolis, IN 46218
Frank
Old Apr 12, 2008 | 10:03 PM
theblur98ss's Avatar
That's the one I'm planning on getting as well.
Old Apr 13, 2008 | 02:04 AM
Jantzer98SS's Avatar
How much ballpark?
Old Apr 13, 2008 | 08:06 AM
UNDER PRESSURE MOD
Less than $2000 depending on how high you want to go. I went with the shorter of the two models. I can get the runways to 5'11" off the ground and the taller one goes a foot higher.
www.gregsmithequipment.com
Old Apr 13, 2008 | 08:41 AM
I think the rolling jack is a must have accessory though. I'm probably gonna opt for the higher one after I do some measuring.
Old Apr 13, 2008 | 01:49 PM
ss_girl's Avatar
Does the caster kit add any height to the lift?
Old Apr 13, 2008 | 05:28 PM
fmowry's Avatar
The caster kit only stays on when you move the lift. You put them on, lower the lift all the way down, and the wheels cause the posts to raise up about a half inch off the floor.
The rolling jack would be nice, but I just jacked the car up while it was on the ground and still on the runways, and put the rear on jack stands on the runways, to work on my wheels. There is a jacking tray to use a conventional floor jack. I didn't try it though.
Frank
Old Apr 15, 2008 | 12:37 PM
Thanks for the feedback. I checked out Gregsmithequipment and will probably go w/ their PP-8S lift, ~$1700 and it comes w/ 3 drip trays, jack bridge and caster kit (the Eagle lift didn't include the drip trays). I'll also get a sliding jack too. 2 things sold me on the Greg Smith unit is the adjustable stop positions (needed to take maximum advantage of the limited ceiling height for storage of 2 vehicles) and their Indy location (should be cheaper for shipping, or may rent a U-Haul to pick-up myself). It's also rated 8,000 lbs vs 7,000 for the same-priced Eagle unit.
It's going to be a tight squeeze in my garage, will probably have to adjust the garage door opener open-stop position to make sure it doesn't bang the back bumper of the car on top while I park my other car underneath. Cant wait to get 'er done!
Old Apr 15, 2008 | 02:04 PM
Sunset01TA's Avatar
How high are your garage ceilings that you guys are putting these in.
Old Apr 15, 2008 | 02:13 PM
2002_Z28_Six_Speed's Avatar
Did you install or how much for the install? Putting the studs in the concrete must of sucked.
Old Apr 15, 2008 | 02:41 PM
Sunset01TA's Avatar
You can rent a hammer drill for like 60 bucks a day.
Then you drill the concrete and install thunder studs or anchors.
Really not to bad.
Old Apr 15, 2008 | 03:37 PM
A 4-post lift does not need to be bolted down (but you can if you want to). Most of them come w/ caster kits that allows you to move it around, can't do that w/ it bolted down. 2-post lifts are a different story, need at least 6" of 3000psi rated slab to bolt those down (more if it's rated above ~8,000lbs).
Depends on how high you need to lift one car to park another under it. Need to allow ~ 7-8" + the height of both cars. Most lifts have locks every 4", but as I mentioned locks are adjustable +/- 2" on the Greg Smith PP-8S lift. Also, if you intend to stack your cars, need to be sure your garage is deep enough so that the overhead door doesn't smack the rear bumper of the car on top when you open it to park the car underneath.
Old Apr 15, 2008 | 05:00 PM
Sunset01TA's Avatar
The Alchemist how tall is your garage ceiling?
or anybody who has a lift in their garage.
I have a 10' garage ceiling and was wandering if this will be enough room?
Old Apr 15, 2008 | 07:18 PM
UNDER PRESSURE MOD
My ceiling is currently 9.5 feet, but it is a false ceiling if you want to call it that. There is nothing above it and I'm going to open it up, and put a loft in part of it and leave the rest of it open above the car so I can park another car under it.
Old Apr 15, 2008 | 07:49 PM
ss_girl's Avatar
Yeah really. What good is a lift if you can't stand up under the car.
Old Apr 16, 2008 | 02:40 PM
fmowry's Avatar
You can see the schematics of the lifts on their website. For the 8s:
http://www.gregsmithequipment.com/do...stallation.pdf
The bottom of the runways is 5'8 at full extension, but the runways are 4 inches tall so the car tires bottoms will be at 6 foot at full extension so add the height of your car to 6 foot to determine how much clearance you will have overhead.
It's still easier to work on a car at 5 foot in the air than it is on jackstands. You can use a mechanics chair to roll around under the car. Still way easier to change oil, pull exhausts, etc. and still be able to use the car for storage.
Frank
