Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
security bit?
Old Jul 24, 2003 | 02:42 PM
Mike00FRC's Avatar
Default security bit?
When looking to take apart the C5 TB, I found its held together with what looks like a torx that has a post in the center of it.
Checked Sears hardware and they stated it was a security bit and that I would probably have to get it form GM. Checked with the local dealer and they stated that they had no idea where to get one.
Where can I locate one?
Thanks,
Old Jul 24, 2003 | 03:40 PM
L-EATER's Avatar
11 Second Truck Club
Default Re: security bit?
Its called "tamper resisant torx" You should be able to pick 'em up at about any auto parts store.
Old Jul 24, 2003 | 03:51 PM
Greg's Avatar
McMaster-Carr (www.mcmaster.com) has them (I don't know if they sell to individules though - it might be strickly to buisiness). 55515A22 is $10.52 and is just like an fold-up allen wrench set (but it's torx).
Old Jul 24, 2003 | 04:23 PM
Mike00FRC's Avatar
Thanks,
I call around to some local auto-parts stores, and if not, I'll give McMaster a try.
Old Jul 24, 2003 | 06:25 PM
ta12sec's Avatar
Couldnt you just get a torx bit and drill a hold in it.
Old Jul 24, 2003 | 06:38 PM
trackbird's Avatar
Sounds good....but they are usually made of hardened steel. Probably not going to work too well...
Old Jul 24, 2003 | 07:38 PM
ta12sec's Avatar
I have had to um..............."modify" tools before had to make some too. You would be all right as long as you had a decent bit and you probaly would want to use a press so u get it straight.
Old Jul 24, 2003 | 08:42 PM
Mike00FRC's Avatar
Thanks guys, just picked up an assorted pack of 6 bits. Local aotoparts store had them.
Old Jul 25, 2003 | 09:26 PM
ss_girl's Avatar
Got mine at napa.
Old Jul 27, 2003 | 03:44 PM
whitez71's Avatar
Thanks,
They sell them at sears
Old Jul 28, 2003 | 10:11 PM
soundengineer's Avatar
used alot in the Audio Industry...try a Music Store(that sells guitars/basses/speaker/amps) and tell them you need a middle atlantic security bit.... I use them all the time when I install rack gear and the Purchaser is worried about theft or tampering.
Old Jul 30, 2003 | 11:05 PM
Mike00FRC's Avatar
Got them already
Thanks,
Old Jul 31, 2003 | 06:52 AM
mikey's Avatar
LS1TECH Sponsor
How's the car running Mike?
