Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Air compressor????
Old Mar 24, 2008 | 10:47 AM
91parkave's Avatar
Moderator
Default Air compressor????
Was wondering if any one ever daisy chained air compressors or had one feeding another. I just picked up another one so now i have a 6-gallon 150 PSI 2.9 SCFM @ 90psi and a 8 gallon 115psi 4.9SCFM @90 psi air compressor, I wouldnt to join the two @ 45PSI and have a "14 gallon" capacity and "8 SCFM" operating pressure. Is this possible? , i If any one could chime in i'd appreciate it.
Old Mar 24, 2008 | 05:47 PM
Dave 96TA's Avatar
I've never heard of that, but I got a Craftsman 2.2hp 26gal 160psi vertical air compressor with extras (impact, ratchet, air gun, inflators) for $179 a couple months ago at Sears.
Old Mar 24, 2008 | 07:30 PM
01ssreda4's Avatar
theoritically that will work. at max psi. but as both of them drains the one with the high turn on will kick on first (and the second will not bc its turn on was not reached) and refill its tank. im sure there is a back feed valve that will not allow it to fill the other. so from step one it will work but after depleting your air supply you will run into problems. bc after the first run then only one will be full the other will be empty.
Old Mar 24, 2008 | 08:45 PM
MikeGyver's Avatar
It would work if you controlled them both off of the lower-pressure compressor's pressure switch, and tee the tanks together. I don't think you will be able to set the switch as low as 45 psi, though.
Old Mar 25, 2008 | 03:32 PM
mrdragster1970's Avatar
6 & 8 Second Club
I have seen an aux tank added, for added volume. As said, I also think on your deal, only 1 pump would ever kick on. Good luck.
