Tranny jack adapter to pump jack
Tranny locates in the same spot each time and clamps to the fixture by the side clamps. Have used it for 2 R&R,s so far works great.
I used the jack tray on my four post to rest the trans on when I swapped flywheels and put in a remote bleeder for the slave cylinder. Not quite as nice as your setup, but it worked well enough.
My biggest issue was not getting it to go into the clutch disc, but it was late so I called it a night. The next day logic kicked in and I put a socket on the crank and turned it just a smidge and the trans went in perfectly.
