Braided Hose....
Thanks
The tool is almost like a vise stand with an cutter.
You put the tubing in it's place on the stand, put the braided hose into it til it reaches the opposite side if you want to cut the braided tubing (slight friction between the tube and the braided tube inside so it requries a light coat of thin oil) then you pull the lever to operate the cutter to make a clean cut.
Then you lock the cutter away, put the stand up and put the AN fitting in it's place and place the AN fitting holder right next to the braided hose and the tube. The braided hose is inside the tubes halves where there should be a very small gap only enough to see if the braided hose went into the fitting, then you push the braided hose into the AN fitting which is inside the AN fitting holder. Then you unlock the AN fitting holder and screw the rest on by hand or with the AN fitting tools provided. Then you remove the tube halves and screw the rest on plus put the internal attachment as per the AN fitting your using.
Don't ask me how much for this tools, it's at least a few grand.
