Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Braided Hose....
Old Aug 20, 2003 | 11:21 PM
02BlueFirehawk's Avatar
Default Braided Hose....
Is there a tool that makes putting fittings on a steel braided hose easier? 8AN goes on pretty easy but the 6an stuff is kickin my ****. Cant get the screw caps on over the steel braid to even begin. Someone had to have invented something.
Old Aug 21, 2003 | 12:50 AM
mighty mex's Avatar
Default Re: Braided Hose....
nothing that i know of
try putting it in a vise. sometimes that works but they should usually just slide right in
are you using the assy. lube for the braided hose??
Old Aug 21, 2003 | 09:30 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Most techs will put tape around the hose where they plan to cut it, so that the braids do not fray out.
Tony
Old Aug 21, 2003 | 12:26 PM
xaon's Avatar
if you think 6AN is a pain... try 4AN. I will NEVER make another 4AN line.
We put electrical tape around ours then cut it in the middle of the tape. It kept the fraying to a minimum.
Old Aug 21, 2003 | 02:24 PM
DERTY's Avatar
The Bull
Electrical tape works the best. Just cut down the middle. I just did some -4, -6 and -8 last night no problem. If you do the tape right, as your twisting it will start to peel off and come out of the cap. Another thing to try is to hold the fitting with a wrench and grab a fist full of hose then turn. It seems to like a little force to get it into the fittings easier.
Old Aug 21, 2003 | 09:13 PM
GeorgeC's Avatar
Wrap the tape as tightly as you can, too...
Old Aug 21, 2003 | 09:43 PM
mighty mex's Avatar
ya tape works real good too
i forgot to mention that
Old Aug 21, 2003 | 10:31 PM
felton316's Avatar
I seem to like the smaller hose. Its when I have to make 20AN and 24AN hoses, is when I start to bitch.
Old Aug 23, 2003 | 03:50 PM
IslandTahoe's Avatar
Can someone tell me if there is a fitting that will go from a plain/flared end of tubing to AN ftg? For example, tapping into the trans cooler lines to run braided hoses to an aftermarket cooler.
Thanks
Old Aug 23, 2003 | 04:08 PM
felton316's Avatar
IslandTahoe, they make those. My shop gets all their fittings from aeroquip. We use alot of flared to tubing connectors for all kinds of marine applications.
Old Aug 23, 2003 | 06:40 PM
Is that the name of the connector "flare to tubing"? Still can't find what the adapter or fitting is called.
Your help is appreciated.
Old Aug 23, 2003 | 09:03 PM
felton316's Avatar
Actually I think they are inverted flare(flared end of tubing) to 37 degree flare (-an fitting). I won't know the official term until I go back to the shop monday.
Old Aug 23, 2003 | 09:40 PM
Appreciate is if you could check that out for me.
Thanks
Old Aug 26, 2003 | 06:12 PM
Any new info?
Old Aug 27, 2003 | 07:34 PM
felton316's Avatar
Sorry it took so long. I went through all our fittings and there is two that sound like what you are describing. One is inverted flare to flare(this is the -an end) and the other is compression to flare. The flare end is actually a 37* flared male end, it is a male -an fitting.
Old Aug 27, 2003 | 08:51 PM
So I'm clear, a tube flare is a different angle than a AN flare.
1) Tube flare to AN flare looks something like:
tube--< <--> >--braided
2) Compression ftg to AN flare looks something like:
tube--- ]--> >--braided
Is this the right picture?
Thanks for the help.
Old Aug 28, 2003 | 07:58 PM
felton316's Avatar
The only difference in angles I know of is whether you get SAE or JIC fittings. Even then the only two that are not compatible with each other is -6an &amp; -12an. All the others will work with each other.
Old Sep 2, 2003 | 01:38 AM
This looks like the adapter I need.
http://www.jegs.com/cgi-bin/ncommerc...mp;prmenbr=361
Old Sep 2, 2003 | 08:49 AM
Reckless's Avatar
Super Moderator
Island Tahoe ... go to Hydro Air (Hydra Air) down near the airport (it's two streets over from Nimitz). They have nearly every fitting you can imagine. Believe me, I put them to the test while I was there many times
Old Sep 4, 2003 | 04:08 PM
Ok will do. Thanks for the info.
