tig welding
penetration is based on how heavy your rocking that pedal.
i usually do 304, MS, moly and 6061 alum. whats in your tri mix? penetration is based on how heavy your rocking that pedal.
i usually do 304, MS, moly and 6061 alum. whats in your tri mix?91% Helium 8% Argon 1% CO2 is what i use. i guess i will need to purge cause i notice what they call sugar buildup on the back side of the weld which is caused from not using the purge method
