Low Budget Lift Solution
luckily we were able to hold the car from falling off, but damn if it wouldnt have been a hell of a mess if it did.
Take your time and be careful.
Not cheap but a cool idea.
I hear you on the tipping jackstands to. My driveway is too wavy to be doing that stuff and I've had them tip a bit but I always keep a close eye on things. I'd love a kwik-lift but don't have the $$$$ for one. I liked this because you don't always need the car 2 feet in the air so you can adjust it to what you are doing.
As usual, I guess it is whatever people feel the safest with. I've done 6x6's, cinder blocks, jack stands, rhino ramps etc. I always would prefer a lift
I just use SEVERAL jack stands. There are 6 under this car right now. Plus 2 holding the k-member up still on my my ATV jack, with my low-pro jack still holding the trans up.
Jacked it up to a low level, used a cherry picker to lift the front of the car up high enough to get the motor out and set it on the jack stands there.
you HAVE TO post pix of where you put your stands. I am always scared to break something when I put my car up and putting it up that high would be soooooooo extremely helpful when I start wrapping my exhaust.
this pic is classic
