Another Poor Man's Lift Solution?
Ok, so the idea is to make a piece like a wheel spacer, and then weld two pieces of 2" x 2" steel to it at 45* angles. These will point down towards the ground, and then weld another piece down at the bottom as a base for it to stand on. Here is a VERY rough sketch of what I'm talking about. The only flaw that I see with this plan is that you would have to have brakes engaged in order to hold the car still. I think that pulling the E-brake would suffice. Do you guys see any flaws in my logic? Speak up if you do cause I'm thinking about trying this and don't feel like dying, lol.
The best thing for being under a car is putting wheels laying down under the wheels or putting all four up on ramps.
Your design needs side-to-side support as well. You've got the fore-aft covered, but shake it hard enough side to side and you may break welds or lug nuts and the car falls sideways.
Also, add a straight vertical piece directly under the wheel for support. The 2 45 degree angle pieces are good for stability, but I'd still put a vertical piece for load support.
Nobody has a lower car than me. It is a pain in the butt, but just get the big truck stands & put it up in 3 steps.
Mine do have the extra pin, but too be honest, I have never used them. I have started & ran it like that many times.
Rock solid, even at 1000+ HP. If someone is that worried, than use 6 stands.
There is very little chance that 2 stands will collapse at the same time.
Especially those monster truck stands, those things are frigging heavy duty. Good luck.
00pooterSS, was this just strictly a show piece that you saw, or did it look like it actually had a practical use to it? Was the design any differenet than mine at all?
Honestly to me it looked to be more for show and it also looked like it was possibly made by that person, sorry its been a very long time since I have seen it, but to be honest I still would not want to be under the car with those supporting it, I always felt most comfortable putting my wheels and tires under the frame while on jackstands, one time here at work a truck fell of the jack of a drive on lift and the tech had the wheels laying on the lift, thats the only thing that saved the truck and the technician.
Anyways, there wasnt' a good place for the jackstands so I made the same syle stands this thread is talking about. I made them very nice and had them powder coated. They looked great at the car shows too.
Here are some pics of the car.
