User Support & Resources Account Problems | Questions | Suggestions
Problem with my sig pic, need a little help.
Old Nov 27, 2008 | 09:48 AM
street demon2k3's Avatar
Default Problem with my sig pic, need a little help.
I've been having prob with my sig as of late. I had a pic off photobucket with the proper size and staying with the sig guidelines. It was removed and just showed up as a link; figured we needed to use the new photo album feature for sig pics. Still having the same problem but my sig pic is just an x, figured I'd ask before I give up...LOL!!!!
I searched the sticky but didn't find anything. I know the [img][/img] tags are correct, maybe I'm not the only one.
THanks!!!
-Isaac-
Old Nov 27, 2008 | 03:31 PM
GEARHED's Avatar
The signature test forum would have been the place to get it to show up like it does now.
If it is a different picture, photo bucket pictures can be resized manually to fit.
Old Nov 28, 2008 | 12:04 AM
Im wondering if the sig works now? If it does, why won't it show on my screen. All I get is a red X and the image link.
Old Nov 28, 2008 | 12:19 AM
Speed Density's Avatar
hashtagBMW
Post what picture you are trying to use Isaac and ill try and get it to work.
Old Nov 28, 2008 | 12:33 AM
Here's the pic I was using before this problem. I tried to insert the pic with the proper tags and still nothing shows up on my end. If you can get it to work that would be great Tony, thanks.
This 1st one is from my photobucket....
And this is the same pic I uploaded using the ''upload sig pic" option.
Old Nov 28, 2008 | 12:37 AM
hashtagBMW
Isaac,
Try and save the picture to your computer and then upload it straight here instead of going through photobucket.
Old Nov 28, 2008 | 12:40 AM
hashtagBMW
nvm, your set it looks like.
CRAGER's Avatar
Administrator
I got it, you upload the pic and then in your sig put in [sigpic][/sigpic]
~ Craig
Old Nov 28, 2008 | 01:08 AM
GEARHED's Avatar
Its odd but it showed in the first post and sized correctly.
What did you change?
Old Nov 28, 2008 | 01:23 AM
Weird, I tried using both tags (img and sigpic) but neither worked. I uploaded the pic and then right clicked on it, properties, and copied/paste the address between the tags.
Thanks for fixing it Craig!!!!!
Old Nov 28, 2008 | 01:35 AM
CRAGER's Avatar
Administrator
Once the sig is up it shows in all of his posts.
After you upload it you're done, all you do is use [sigpic]nothing here[/sigpic]. You insert nothing there at all.
This is your sig:
'94 Camaro M6 (31xxlbs)
cc306 + full bolt-ons
12.7@114mph on street tires
[sigpic][/sigpic]
~ Craig
Old Nov 28, 2008 | 11:37 AM
THANKS again!!!!
