User Support & Resources Account Problems | Questions | Suggestions
search does not work!
Old Mar 5, 2009 | 09:33 AM
  #41
WSsick's Avatar
they changed the search to solve other problems but they made it 1,000x worse.
get this stupid shitrag of a search out of here. it turns up absolutely nothing you look for.
Old Mar 5, 2009 | 10:00 AM
  #42
nahasapeemapetalon's Avatar
+1 Search is ineffective.
Old Mar 5, 2009 | 10:05 AM
  #43
9000th01ss's Avatar
It's been working fine for me.
You pretty much have to narrow it down to one word and search the forum it's most likely to be in.
For example if you want to search flash stall to find out the definition. You might go to the auto trans forum and type flash stall speed, and all the results are going to be more related to stall speed, stall converter.
For stuff like that I just search for flash in the A4 section.
Old Mar 5, 2009 | 10:07 AM
  #44
allbaugh_04's Avatar
Well keep posting up in here till they switch it back...it sucks the way it is now.
Old Mar 5, 2009 | 11:11 AM
  #45
EvilStang's Avatar
STF Veteran
search is def screwing me over. we need the relevance button back!!!!
Old Mar 5, 2009 | 04:22 PM
  #46
jattgunman's Avatar
search has been fd up but if you use quotes. "subject" it works
Old Mar 6, 2009 | 10:21 AM
  #47
import_raper's Avatar
Sooo are they working on fixing the search, or is this just the way it's going to be now?
Old Mar 6, 2009 | 11:46 AM
  #48
oifish's Avatar
I have learned to not use search on this website, If I want to find something I use Google: keyword, and then type: ls1tech, and usually that works for me.
Old Mar 6, 2009 | 01:06 PM
  #49
turbozcamaro's Avatar
search still not working, I wish they would bring back the old one!!!
Old Mar 6, 2009 | 01:55 PM
  #50
anyone pm a admin yet?
Old Mar 6, 2009 | 02:00 PM
  #51
fccs's Avatar
If a admin doesn't know about this by now, they never will! Its going on almost a week now, I feel retarded having to make threads for questions I have because I CANT USE THE SEARCH, so its pretty stupid still.
Old Mar 6, 2009 | 02:21 PM
  #52
IB Advertising's Avatar
IB Staff
Have you checked the search yet? It was fixed on Tuesday this week.
Marvin @ IB
Old Mar 6, 2009 | 02:37 PM
  #53
OhTwo's Avatar
Marvin @ IB
Not from what I can tell. I just did a search for GROUND CONTROL as two separate words - no quotes and not in caps. It used to be an AND condition between the words and now it's an OR. It found links with GROUND or CONTROL and even some with GROUND and CONTROL. Not the best example since they could be in quotes but try KONI LOWER - same result - returns KONI or LOWER links not just links with both KONI and LOWER. I'd like to see it back to an AND condition. Hope that makes sense.
Old Mar 6, 2009 | 05:17 PM
  #54
IB Adrian's Avatar
IB
We will be adding the relevancy function back shortly (hopefully Monday), sorry about the inconvenience.
Adrian
Old Mar 6, 2009 | 09:06 PM
  #55
jermzz's Avatar
it works fine if you quote everything.
Old Mar 7, 2009 | 08:11 AM
  #56
Originally Posted by ib adrian
we will be adding the relevancy function back shortly (hopefully monday), sorry about the inconvenience.
Adrian
thank you
Old Mar 7, 2009 | 09:09 AM
  #57
jetlag's Avatar
But that limits the search and may leave out good topics.
Old Mar 7, 2009 | 12:01 PM
  #58
7998's Avatar
It sucks!!!!!!!!!! I'm trying to search for transmission filter change I quoted it and nothing.
Old Mar 7, 2009 | 12:17 PM
  #59
OhTwo's Avatar
The quoted searches only show results if the words in the posts are in the exact order of those in the quotes.
Old Mar 7, 2009 | 12:26 PM
  #60
jermzz's Avatar
I like it thise way cause I find exactly what I want.
before I would type in something and the majority of topics that came up had nothing to do with what I wanted.
quoting gets me word for word what I want to know.
