User Support & Resources Account Problems | Questions | Suggestions
search does not work!
Old Apr 24, 2009 | 12:28 AM
  #141
Sharpe's Avatar
Thanks. What types of changes were made, if I may ask?
Old Apr 24, 2009 | 12:36 AM
  #142
IB Adrian's Avatar
IB
Lots.
We fixed all the known bugs in it essentially (I think there was around 10 different items). Save your search preferences to return results by relevance, and give it a try.
Here are some tips:
http://www.sphinxsearch.com/docs/cur...boolean-syntax
You can also still use the quotation marks for phrases!
Old Apr 24, 2009 | 12:48 AM
  #143
Sharpe's Avatar
Oh. My. Gawd.
On first inspection... ireally seems to work just like in the old days!
Searched using quotes for "Black ZR1" and got GREAT results!!!
Tititively, with apprehensions, I sincerely congratulate you on the accomplishment!
Originally Posted by IB Adrian
I am going to answer yes and no.
We are doing changes and improvements, but is part of a more wholistic and integrated search package, and therefore not going to be available till about July or so.
The existing search has been tweaked as much as we possibly can, and there is little more we can do to it for the time being.
What changed in the plans? Was this revamp the result of something unexpected?
Old Apr 24, 2009 | 12:54 AM
  #144
Sharpe's Avatar
And, whatever the case is, thanks again. Did some more searchees and got great results.
Good job, Adrian.
Old Apr 24, 2009 | 10:39 AM
  #145
oddwraith's Avatar
Thanks for doing this. It will make everyone's experience more enjoyable and informative.
Old Apr 27, 2009 | 11:37 AM
  #146
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Search function is very much improved! Thanks for the upgrades.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Apr 27, 2009 | 04:10 PM
  #147
IB Adrian's Avatar
IB
In doing our bigger change to search, we discovered some items that we could fix.
Old Apr 27, 2009 | 10:54 PM
  #148
Sharpe's Avatar
Well, thank you very much. I really have had no issues since the fix.
Old Apr 28, 2009 | 03:12 PM
  #149
bearcatt's Avatar
I miss the old search.
Old Apr 28, 2009 | 04:43 PM
  #150
Sharpe's Avatar
What?! You joined in July, 2007. Do you even remember the "old search?!" You know, the one that went down like every two weeks?! Or, was that sarcasm?
As far as I can tell, this search finds things as well if not better than the "old search." So, the "old search" found things as well but went down every time the wind blew. I'll take this one any day, from what I can see so far.
Old Apr 28, 2009 | 08:48 PM
  #151
bearcatt's Avatar
Old search is a relative term. Perhaps I could have said prior search.
The previous search (old to me) seemed like the results were more relevent.
As far as search downtime, I've never experienced that.
Old May 26, 2009 | 02:20 AM
  #152
jattgunman's Avatar
I still cant use the search...any one have tips?
Old May 26, 2009 | 02:51 AM
  #153
Sharpe's Avatar
In the last month, I maintain my opinion that search works as well if not better than ever before.
What are your issues? What keyword are you trying in the Advanced Search Keyword field?
Searching by relevancy still seems to work a tiny bit better for me. To do that, select "relevancy" from the 'Sort Results by" drop down menu under Search Options. It's right below the Keywords field. Searching by forum section helps a lot too, of course.
But, just plain old search normally works fine for me.
Hope that helps.
Old May 26, 2009 | 11:26 AM
  #154
jattgunman's Avatar
I tried searching "car wont start" with the relevancy option choosed but..I think i figured it out you set the keyword to: search titles only and then set the sort results by:relevancy
