User Support & Resources Account Problems | Questions | Suggestions
PM problem
Old Dec 17, 2009 | 03:41 PM
BLUEBYU's Avatar
Default PM problem
Cannot receive PM's... can you help or direct me in how to get this working?
Thanks.
Old Dec 17, 2009 | 05:05 PM
Sharpe's Avatar
Sent you a test.
Old Dec 30, 2009 | 11:47 AM
BLUEBYU's Avatar
Not received.... sorry for delay.
Old Dec 30, 2009 | 03:59 PM
Sharpe's Avatar
Click on User CP in the upper left then click on Edit Options on the left, then check your Private Messaging options. There are four options there. The first one needs a check mark.
Old Dec 30, 2009 | 06:53 PM
JeremyT's Avatar
I have a feeling this may not be the issue. If a user does not have PMs accepted, Moderators cannot contact them via PM as the feature will be disabled. It won't go into a void. Administrators, however, are exempt from this rule. This means that if you were able to send a PM, as a Moderator, then the user must have the feature enabled.
If the user had the feature set to only Contacts and Moderators, then I would not be able to send a PM to the user. I have not done so, but it shows the user does accept PMs and I can send the user one.
Only thing I could think of is the ignore feature, but that shouldn't be the case, here.
