User Support & Resources Account Problems | Questions | Suggestions
What is this message?
Old Mar 14, 2010 | 01:51 AM
lscorvet's Avatar
Default What is this message?
Hey,,
I got this message when sending a private message.
"Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error."
Thanks
Old Mar 14, 2010 | 03:31 AM
CRAGER's Avatar
Administrator
I just logged into your account and sent myself a PM just fine.
Try it again and if it happens do a screenshot and show me please.
~ Craig
Old Mar 14, 2010 | 08:08 AM
JeremyT's Avatar
This error can be caused by a modification (plugin) to the software, incompatible/old vB files or templates. If this was just a one time occurrence to you, then it was most likely a browser cache issue - which is why Craig didn't see replication.
Old Mar 14, 2010 | 10:07 AM
lscorvet's Avatar
It happend couple of times today, but now it's ok.
Thanks
Old Mar 14, 2010 | 02:55 PM
JeremyT's Avatar
Make sure you delete your cache. Did you do before it reoccurred today? Outside of sending a PM, what other areas caused the message? As I mentioned, that error is commonly associated with a modification of the forum that isn't playing correctly, or template issue. However, since nobody else has reported such, and no changes have been made to suddenly cause this, the most likely culprit is stale browser data.
