PNG Images
PNG images provide transparency unlike JPEG images. I began making all of my signatures in PNG format so they would be "universal" for forums. Unless you have a square border there is only two ways to make a non geometric image work. You can color the background to match the site or use png and make the image transparent. The problem with coloring the background is that while it may work great on here it would clash with Z28.com's or Northern Kentucky Fbody's white and blue backgrounds.
Here is a signature that does not work here when trying to add as a signature. If I upload the image it changes the transparency to white and ruins the image look.
I don't believe bandwidth is the issue here. I believe it was abuse. There's more control when the images are hosted on LS1Tech's servers than if it's allowed to be hosted anywhere else.
Please ensure your .png file meets the exact size requirements for member sig images, I think that will solve your problem.
cheers,
robb
Ethan, give this one a shot, see if it works for you.
Maybe try right clicking and saving from this, I re-saved it:
http://dl.dropbox.com/u/73557/Tropica.png
Looks like the "Show your signature" option isn't checked for your above post. Did you disable it? Or was it not selected by default?
