User Support & Resources Account Problems | Questions | Suggestions
ranking question
Old Mar 15, 2006 | 03:32 PM
daryl2cb@yahoo.com's Avatar
Default ranking question
What Are the post #'s for all of the ranking?
I just noticed I made tech apprentice.
Old Mar 15, 2006 | 09:16 PM
ACW's Avatar
ACW
Here is the list
0-49 = Teching In or Registered User
50-99 = Staging Lane
100-199 = On The Tree
200-299 = Launching!
300-399 = TECH Apprentice
400-499 = TECH Regular
500-749 = TECH Enthusiast
750-999 = TECH Resident
1000-1999 = TECH Fanatic
2000-2999 = TECH Addict
3000-3999 = TECH Junkie
4000-4999 = TECH Veteran
5000-? (7K+) = TECH Senior Member
https://ls1tech.com/forums/showpost....76&postcount=2
Old Mar 16, 2006 | 11:45 AM
Thanks ACW got a while to go I guess
Old Mar 16, 2006 | 12:03 PM
~JOSHUA's Avatar
Time flys when you're having fun. You'll see.
Old Mar 19, 2006 | 08:46 AM
inaccord's Avatar
Does it mean you get 1 ranking # per post? Is that how it works?
Old Mar 20, 2006 | 05:30 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
What?
Old Mar 20, 2006 | 06:37 AM
cyphur's Avatar
It seems you're having trouble with this concept. ACW laid it out for you:
Originally Posted by ACW
Here is the list
I've highlighted the RANGES on the posts, where you can fall into. In those ranges he's also listed the corresponding user title.
Your post counter increases 1 for every 1 post you make, except in certain non-technical forums, in which case your posts will not be used to count towards your total post count. Read this sticky for more information on forums where post counts do not "count": https://ls1tech.com/forums/removed-locked-thread-graveyard/208057-posts-do-not-count-some-forums.html
I hope this clears it up for you.
Old Mar 20, 2006 | 07:33 AM
~JOSHUA's Avatar
If the ranges are dead-on then I shouldn't be a "Tech Fanatic," I should be a "Tech Addict." Or better yet, "Polishing Addict." -Joshua
Old Mar 20, 2006 | 08:10 AM
cyphur's Avatar
That is b/c when you get a custom title and then it is taken away, we can't reset it to normal quite right. So you're stuck at TECH Fanatic as long as you're here.
Although if you keep asking for a custom polishing title, I do have one in mind for you.
Old Mar 20, 2006 | 08:13 AM
~JOSHUA's Avatar
Oh. I guess that settles that.
Old Mar 20, 2006 | 08:15 AM
777's Avatar
777
I think I have an idea of what that might be
Old Mar 20, 2006 | 08:27 AM
~JOSHUA's Avatar
I do too. Sucks to think that someone is pissed off at me.
Old Mar 20, 2006 | 08:32 AM
cyphur's Avatar
Not pissed at you. Your constant mentioning of a custom title, after dozens of mods have already shot it down, can be a little annoying. Its like being pesky, the way a 7-9 year old would be about something.
I know you aren't 9 years old, hence why I keep gently reminding you its not happening. This time I wanted it to be more direct to be sure to get the point across is all. Its unfortunate that "no" isn't as clear cut as it used to be in many respects.
I don't have anything against you personally, that is just my opinion on the whole matter.
Old Mar 20, 2006 | 08:37 AM
~JOSHUA's Avatar
Yeah I hear 'ya. I can garauntee you'll never hear another piece of crap exiting my mouth about user names. -Joshua
By Brett Foote | 2026-06-04 05:00:17
