User Support & Resources Account Problems | Questions | Suggestions
Can a Mod fix this?
Old Apr 25, 2007 | 08:43 AM
turbotank's Avatar
Account Disabled
Default Can a Mod fix this?
Ok for some reason I cant access my other username "Tricked-Out-Toy" and its my name on All my other sites (camaroz28, MTFBA, NJFBOA, and thirdgen.org) and I would like to have it back. Is there a way to get it released or unlocked or at least tell me what happened to it? I havent been on this board much since I never owned an LS1 and back in 2004-2005 the LT1 section was pretty weak. Now im working on getting an LS1/LS2 and would like to be a little more active on this site. Thanks!
Old Apr 25, 2007 | 09:47 AM
amsterdamn's Avatar
You did create this account back in December '05 correct? It appears the username is still active. Are you sure you are logging in with the correct password? Or, maybe you're trying to create a new account with the same username?
Old Apr 25, 2007 | 09:56 AM
Vendetta's Avatar
Um somebody else probably registered it, in which case you're out of luck.
Old Apr 25, 2007 | 10:12 AM
cyphur's Avatar
The account is still active - and while it shows the same IP used, it is registered with a different email account. Both are Gmail accounts.
If both are yours, you need to choose one to use, as the other will be disabled.
Old Apr 25, 2007 | 11:03 AM
turbotank's Avatar
Account Disabled
Hmm ya both are mine but for some reason I couldnt get into it. Ill try again. Thanks!
Old Apr 25, 2007 | 11:09 AM
turbotank's Avatar
Account Disabled
Cool can you delete the Turbotank Account? Thanks I must have been using the wrong email account to try to get the password sent to me, do,oh! thanks again!
Old Apr 25, 2007 | 11:10 AM
Tricked-Out-Toy's Avatar
Fixed..
Old Apr 25, 2007 | 02:42 PM
cyphur's Avatar
Done.....
