User Support & Resources Account Problems | Questions | Suggestions
Signatures??
Old May 2, 2007 | 08:14 PM
02NHRAtransAm's Avatar
Default Signatures??
Not trying to raise o fuss or what not but i have resized my sig to the 500x150 limitation and it has been deleted for the second time?? Am i doing it wrong? I love ls1tech and the last thing i want is a "vacation" so can someone shed some light on this for me? I even deleted all the text i had in my sig and just had the pic this time. Thanks for your time
Old May 2, 2007 | 08:16 PM
to be techn. it is 437x150 according to my program
Old May 2, 2007 | 08:58 PM
staringback05's Avatar
it seems you have TWO images.....you realize both together have to be less then 500x150
Old May 2, 2007 | 09:03 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I didn't see what your sig looked like before, but this is the truth. Total of all images cannot be larger than 500x150.
Old May 3, 2007 | 08:05 PM
that was the total of both of them together....
Old May 3, 2007 | 08:40 PM
unit213's Avatar
Administrator
Speaking of sigs and blatant disregard for to my requests, see you in a
week.
Old May 3, 2007 | 08:42 PM
cyphur's Avatar
week.
He's received more than 3 warnings, that is fo sho.
Old May 3, 2007 | 08:44 PM
unit213's Avatar
Administrator
Can you post up your sig pic here please. We'll take a quick peak
at it. Keep in mind that animated sigs aren't allowed.
Old May 7, 2007 | 09:22 AM
Old May 7, 2007 | 09:36 AM
cyphur's Avatar
I edited your signature - hope you don't mind - to see whether image showed up differently for whatever reason when used as a signature. It doesn't, and the size shows up fine for me.
I've removed the warnings from it as well(somthing you could have done yourself if you had wanted). Hope this helps! FWIW, size shows up as 437x150.
Old May 7, 2007 | 09:43 AM
cyphur's Avatar
OK, after doing a little research, I found one of the times you were warned, on 4/30. It was due to you having a night rider car GIF as well as having the image shown above. The cumulative total of both images exceeded the 500x150 due to the fact that the above image is 150 pixels high to begin with.
If you wanted to size down the larger image, you could add the night rider image back in, as long as the cumulative total is 500x150 or less.
Old May 7, 2007 | 03:45 PM
thanks man you rock!!!!
