95 Camaro 275 Drag Radial/Street Car
95 Camaro 275 Drag Radial Car
355 sbc, Maley Flat Top Pistons, Manley 6" in rods, GM Forged Crank, Dart Iron Eagle Heads - 49cc chamber 230cc intake runner 2.08 intake 1.6 Exhaust, Cam is .557 intake .542 exhaust, Eldebrock intake, 850 Demon Carb, NX Twin Gemini 2 Stage Plate-possible 800 horse kit. CSI Electric Water Pump, MSD Distributor, Crank Trigger, MSD 75301 Digital Programmable Box, NOS Nitrous Progressive Controler, Headman Headers/ 3 inch Flowmaster Muffler
Transmission
PowerGlide with 1.76 first Gear, TCI Ultra Bell bell housing, Coan 8" converter, 4500 rpm. 3" moly driveshaft
Suspension
Strange 12 Bolt Rearend, Strange Brakes all the way around, AJE K-member and lower control arms up front, BMR Torque Arm, BMR Lowers and BMR Panhard Bar out back. QA1 adjustable struts and shocks. Rear Coilover adjustable spring mounts in stock location. Minitubbed. 15x4" Weld Pro magnums in Front, 15x10" Billet Specialties Comp 5 Rear Wheels-Both Powder Coated Black. MT 275/60/15 on Rear. Wolfe 10 point Chromoly Cage. Good to 8.50.
Car weighs 3250lbs with 220lb driver. Has 80lbs on ballest in Rear. Has been 9.70 @ 138 on a 200 shot. Had a 1.40 60' on rear tires. Turn Key $16000.00 obo. All wiring is there for Headlights, Tailights and Turn signals. Good window motors with wiring. None currently wired up due to car not being driven on street. $10,500 as roller. Call 309-251-4667 or 309-222-3076 or email me at ls1lt1cam@yahoo.com if you have any questions after 5pm central. Have pics of the car. Will post up tomorrow
Transmission
Suspension
