1991 eagle talon Clean built motor/trans etc. want to trade for f body
Year: 1991
Make: Eagle
Model: Talon
Price: $6500
Mileage: 253000
Private or Dealer Listing: Private Listing
Location (State): NJ
Color: Black
Transmission: Manual
Drivetrain: 4WD & AWD
LS Engine?: Car has other engine
1991 Eagle Talon Modification List
Eagle rods
Wiseco pistons 9.0-1 CR standard bore
ACL Race rod and main bearings
New Oem oil pump
New Oem water pump
New Oem balance shaft removal kit
New Oem Forward facing oil filter housing
New Oem lower timing cover
New Oem oil squirters
Unorthodox polished crank and alternator pulleys
Head O-ringed and decked by M2 race systems
Oem metal head gasket
ARP head studs
HKS 272 cams
Evo beehive valve springs
Oem valve stem seals
Extrude hone ported stock intake manifold
Spearco/Turbonetics FMIC with 2.5” stainless piping
Tial 50mm blow off valve
MKIV supra fuel pump with rewire
Precision 1200cc injectors
SX fuel pressure regulator fuel rail mounted
Buschur alternator relocation
Dogbox Racing RACE transmission with 4 spider center differential
Quartermaster Twin Disc Clutch with Fidanza Flywheel
Full 3” exhaust with borla muffler
Evo 3 exhaust Manifold
Tial 44mm wastegate mounted on exhaust manifold dumped to atmosphere
Garrett GT3076 turbo
Hallman manual boost controller
Forced performance intake pipe with K&N filter
Upgraded dual piston front brakes
Stainless braided brake lines
Polyurethane control arm bushings
Evo 8 wheels with Kumho MX tires
Ground Control Coilovers
Koni Yellow struts in rear
Kyb gr2 struts in front
Stewart Warner boost gauge 30-0-40
Aem Ems with 3.5 bar map sensor
Aem Wideband
HKS turbo timer
Pioneer head unit
Infinity speakers all around
Dogbox Racing short throw shifter
New Oem Clutch pedal assembly
Air Conditioning and power steering removed
Engine bay freshly repainted
Battery relocated to rear of car with NHRA approved box and kill switch
Stainless braided clutch line
New slave clinder
4 bolt rear end upgrade
New driveshaft yoke
All new u-joints and OEM carrier bearings
![](http://i3.photobucket.com/albums/y95/Girken22/mevsevoX.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/3832454130_eb6480bb20.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/3832454072_97a9d2eb09.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/018.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/DSC00208.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/014.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/002.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/003.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/004.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/005.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/009.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/011.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/017.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/016.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/020.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/015.jpg)
![](http://i3.photobucket.com/albums/y95/Girken22/012.jpg)
