2000 z28 (not running) fs/ft
Year: 2000
Make: Chevrolet
Model: Camaro
Price: $555555555
Mileage: 2147483647
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Beige
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
The car is a pewter 2000 z/28, im going to give yall a quick rundown of the mods on it:
custom pat g cam, 230/234, 918 springs, hardened pushrods, ls6 ported oil pump, new oil pan gasket new front seal as well.
tranny has a tdp stage 3 clutch, tick master cylinder,new rear main seal, new billet flywheel, new pp, new pilot bearing and input shaft, hurst billet shifter
rearend is a moser 9 inch, 35 spline axles, drain and fill plugs, 4inch studs, strange nodular center section, full spool with 390 gears, has a lil whine around 65 and up, front seal on the rear is leaking a lil fluid not bad i just noticed it was moist when inspecting the other day, had rpm speed lca's, bmr panhard bar, spohn adjustable tranny mounted torque arm, factory shocks/springs, it has a strange 1500hp rated driveshaft that goes along with it as well
has a dynotune wet kit with a nx maf kit injecting it into the intake, pilled for a 150 shot, i have pills also for a 175 shot as well, i still have the single nozzle kit and pills that used to be on the car kit has purge and lpe 2 step
The exterior has a dent behind the door on the quarter panel, the hood used to have stripes that i peeled off, the inside is ok drivers seat is ripped up and one little one inch crack in dash
This is the deal i would like to trade it for a truck or a car with some room maybe another fbody idk yet so shoot me some offers i need something already running and ready to go, tags and inspection are up to date and i have clean title in my name. ive got some money invested in the car and was goingto do paint and body next but it took a **** on me,
you can call or text me for pics 254 421 1018 i have a couple in my album under my name thanks alot
im in central texas Temple
sorry i didnt put that in my add, i put it in the texas section and forgot to post it here, i would like to get as close to 5k as i possibly can just the way it sit, and i havent sprayed the car in a good while, the last time i did spray it was at the track and everything was fine afterwards, that was 2 months ago
