2001 Twin Turbo C5R block ZO6 12,800 Miles
Year: 2001
Make: Chevrolet
Model: Corvette
Price: $30000
Mileage: 12800
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Right now the car starts but does not idle well as it needs to be professionally tuned. The engine has not even been broken in but is built with the best parts that money can buy. If someone wanted to buy the car as it is I am willing to sell it for 30,000 as is or if i part it out it would be for:
Engine & Turbo: $16,000
Engine: $11,000
Turbo: $5,000
Clutch: $1,700 ($3,500new)
PM or Email any questions.
Mod List:
C5R GM Performance Parts block ($6.5K new)
TFS 245 Heads
Callies Crank
Oliver Rods
Custom CP Pistons
Fast 92 Intake
NW 92TB
Fast fuel rails
96# low imp. injectors
Yella Terra Rockers
Comp Cams hyd. roller cam
Custom Comp Cam Specd by Jeff@TPE
Double roller timing chain
SLP high volume oil pump
Tall valve covers
Driveline:
RPS triple disc carbon/carbon clutch (<500 miles and works GREAT)
Includes twin disc McLeod clutch/flywheel
New passenger side driveshaft
Baer slotted/drilled rotors (stock size up front, 14" in rear)
Power adder:
Pro Turbo Systems Twin Turbo system (twin T-64 turbos) (The real Kit)
E-boost 2 boost controller
Fuel System:
Twin intake high volume fuel pumps (1 in each tank)
-10 AN feed line
-8 AN return line
Boost referenced adjustable fuel pressure regulator
Electronics:
Road runner PCM (includes EFI Live and LS1 Edit)
Stock PCM included
Wideband Commander AFR gage (drivers downpipe)
LC1 Wideband system (passenger downpipe)
MSD Blaster ignition coils
Miscellaneous:
Battery relocated to trunk
Borla cat back exhaust
Kooks X-pipe (Cats removed)
B&M short throw shifter (stock ****, boot so it looks stock)
Under hood Mirrors
Thicker Tunnel Plate
Stainless Gauge Bezels
![](http://i25.photobucket.com/albums/c61/navymitch12/TTC5Z/IMG_0950.jpg)
![](http://i25.photobucket.com/albums/c61/navymitch12/TTC5Z/IMG_0953.jpg)
![](http://i25.photobucket.com/albums/c61/navymitch12/TTC5Z/IMG_0954.jpg)
![](http://i25.photobucket.com/albums/c61/navymitch12/TTC5Z/IMG_0955.jpg)
![](http://i25.photobucket.com/albums/c61/navymitch12/TTC5Z/IMG_0956.jpg)
![](http://i25.photobucket.com/albums/c61/navymitch12/TTC5Z/IMG_0958.jpg)
![](http://i25.photobucket.com/albums/c61/navymitch12/Corvette%20Engine%20Build/1.jpg)
![](http://i25.photobucket.com/albums/c61/navymitch12/Corvette%20Engine%20Build/2.jpg)
![](http://i25.photobucket.com/albums/c61/navymitch12/Corvette%20Engine%20Build/3-1.jpg)
![](http://i25.photobucket.com/albums/c61/navymitch12/Corvette%20Engine%20Build/4-1.jpg)
![](http://i25.photobucket.com/albums/c61/navymitch12/Corvette%20Engine%20Build/5-1.jpg)
Thanks,
Mitch
