FS: 88 Red 944S w/LT1 $8.5k Renegade Hybrid kit
Year: 1988
Make: Porsche
Model: 944
Price: $8500
Mileage: 120000
Private or Dealer Listing: Private Listing
Location (State): MT
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
All things work. All gauges, electronics, etc.
Even the trouble spots for porsche's - Sunroof, rear hatch release, clock, dash all in great shape. They have been fixed (they usually break). Car has been gone through by western corvette in Calgary, Alberta. When I bought it, it needed about $5k worth of stuff (at $105/hr). Most was pretty easy stuff, loose hose here, clamp this. I took care of most of the small stuff, now all that is left is the tune and someone to do something with this. It runs and drives fine, but you are leaving power on the table according to Western corvette. That and the muffler which makes is real quiet are restricting the power.
The weak points on the car all have been addressed (porsche engine is responsible for 7/10 weak spots on a 944) with the engine swap. Renegade hybrids LT1 corvette conversion kit, reliable and engineered to be so (hundreds sold). the other 3 have been taken care of above.
It is basically 100% stock Porsche 944S (bigger brakes and swaybars, etc) with a vette engine (+clutch). A 4 seater corvette for 1/2 the price, and ~300lbs less.
Running and driving for a few thousand miles. [edit, just so we are crystal clear, the LT1 is in the porsche and it has been running great. I have addressed over time, the Western corvette's inspection's findings that were needed.]
pics at: Picasa Web Albums - 944SV8
Basics:
$3000 LT1 Engine rebuilt & Balanced - D&W (canadian prices sorry they are high $)
$2300 Renegade Hybrids swap kit
$1000 parts for conversion (GM accessories, etc)
$0.00 Installation ~100 hrs.
$750 headers
$250 stock gauges to work with swap
$400 10.5" upgraded clutch
$250 flywheel
$750 944Turbo transaxle
$200 new brakes (pads/rotors)
TOTAL 12,750
+ 944
+ labour.
options which are for sale elsewhere, and may not come with the car
750 turbo front end and all parts for a turbo look swap
750 forged rims & tires (the chrome one in the photos)
100 lots of little parts from the LT1
250 new not rebuilt CV axle
100 new axle bolts - special non-loosening type
400 2tone beige interior parts
Cash talks. You will see in one of the pics why its for sale, as it became redundant.
Attention grabber:
amazing car z51 LT1 LS1 z06 f55 brembo turbo rwd 5.7L 350 coilovers camaro corvette koni
In the interest in full disclosure, here is all what western corvette found.
Tune
Car has LS1 edit, and as such, comes with a laptop to tune. No way am I going to do that.
Car is currently running off one 02 sensor bank, not 2, and as such see above, tune isnt' ideal, but it runs pretty good to me.
SWAP
Leaks - yes, the new rebuilt engine has a leak or two. The heads have a leaks/sweats either on the intake or valve cover. It isn't bad, and its just oil.
Leaks - I think the power steering hoses leak, or have been fixed, but it won't be bad either way.
Leaks - the rear differential is sweating from the axle joints. When I was about to do the axle.
Radiator
It is the stock 944S (Larger), but its still old and stock. I could not get it to overheat w the fans turned off, but it is the stock item.
Tune
SWAP
Radiator
