2000 camaro 418ci nitrous motor drag radial street/strip
Year: 2000
Make: Chevrolet
Model: Camaro
Price: $14000
Mileage: 53000
Private or Dealer Listing: Private Listing
Location (State): NC
Color: Beige
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Engine is a 418 with a LQ9 iron block bored 30 over,fully blue prited. And a balanced eagle 4.1"
crank and eagle 6.2 inch Rods
Custom (Arias) Piston for spray
if you want to use it, L92 Heads
Fully Ported by Felber Race Engineering out of Floida.Dual springs,Stainless valves.Hydraulic Lifters.1.7 Roller Rockers Ported oil pump
Cam 248/254 .615/.623 -110 lsa
Eldelbrock single plane intake,
port matched and lightly ported 4 hole card spacer.also port matched. Holly 950 Carbrator.
Holley big shot 2-stage plate kit.
MSD Ignition with 6 timing curve Modules.Msd High Torgu Starter,A Very wel built TH400
Tranny with Transbrake and RMVB
B&M Pistol Grip shifter.
3.5" aluminum Drive Shaft,4500 stall convertor,Moser 12 bolt
Spool Rear End and 33 spline Axles with
3sets of gears 410,456,514,currently has 456
instaled. Supension has a Spohn drag swaybar,adjustable torque arm,control arms and relocation brackets.Custom fuel sytem is
Aeromotive A1000 fuel pump This car has not been cut or butchered up and is a very nice piece,the list goes on if you need to know more or have any questions just ask.
Hal QA1s on all 4 corners
Has been 6.0x's on 1 stage
CALL CRAIG AT 757-559-4226
