Built 1999 Trans Am th400 9inch SOLD
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $0
Mileage: 32000
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Gray
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Car is a 1999 Trans Am w/ 32k and is immaculate. Car was originally a 6sp car.
List of Modifications.
Car has Moser 9 inch with aluminum center section, spool, 3:73 gears which is back cut to be lightened, 35 spline axles that are gun drilled and star flanged w/5/8 studs. Car has Wolfe double adjustable lower control arms and pan hard rod. Wolfe single rear drag bar and BMR extreme duty torque arm. Coan TH400 w/billet input shaft and heavy duty drum/sprag and trans brake. 8” 4800 billet Coan nitrous converter JW bell housing, 3 in steel driveshaft and TCI flywheel. Motor is a 370 cu with eagle rods and JE pistons w/cryo treated factory crank, cometic .040 head gaskets, TFS 225 heads, 243/249 nos cam and lightweight yella terra rockers, ATI race balancer, meziere race electric water pump, BMR lower alternator mount. FAST 90 w/ 90 NW TB. 42 lb injectors. Direct port NOS fogger and Digital MSD window switch. External 240 BG fuel pump for nitrous. BMR K member and lower control arms with manual pinto steering rack and travel limiters. Qal front adjustable shocks Kooks stainless headers 2 inch primaries and 3.5 collectors. Custom single 4 inch over the axle exhaust. Powder coated front weld magnums and rear hole shot wheels with Hoosier front runners and 28 x 10.5 MT slicks.
Car has been to the track once and ran a 10.91 and 10.83 w/4:10 gears on motor and foot brake. Car was setup to run on NOS. has never been sprayed. The nitrous system wiring still needs to be completed. I’m selling due to I no longer have time enjoy. Not interested in any trades. Serious inquiries only
Will have additional pics up shortly. Please pm me w/any questions
