89' Ford Mustang LS1 Powered Drag/street car
Year: 1989
Make: Ford
Price: $16000
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
This is a street legal car. Ready to move onto a new project. Car has run 9.90@ 138 on motor in the florida heat. Has gone 9.29@ 147 on a 150 shot in the heat DETUNED on 93 pump gas. All parts are new with less than 50 passes on them.
Engine specs :
NEW GM LS1 ALUMINUM BLOCK WITH DARTON SLEEVES
LUNATI 4.100 " STOKE CRANK
LUNATI 6.125 RODS
LUNATI 4.100 PISTONS WITH 1.5 1.5 3MM RING PACK
ARP MAIN AND HEAD STUD KITS
PATRIOT 6.0L HEADS CNC PORTED WITH 2.06 INT 1.6 EXH VALVE WITH DUAL SPRINGS AND TI RETAINERS
GM PERFORMANCE PARTS HYD. LIFTER SET
CRANE CAMS CUSTOM GROUND HYD. ROLLER
CLOYES DOUBLE ROLLER HEX A JUST TIMING SET
CUSTOM .120 WALL PUSH RODS
ATI BALANCER
JW FLEXPLATE
LS6 PORTED OIL PUMP
CAMARO OIL PAN AND PICKUP
CRANE CAMS FIRE WIRES
CAMARO LS1 COIL PACKS AND BRACKETS
NGK TR6 SPARK PLUGS
PRO SYSTEMS 4150 CARB
EDELBROCK VICTOR JR. INTAKE
MSD 6010 PROGRAMMABLE IGNITION BOX
KOOKS 1 7/8 TO 3.5 " STAINLESS STEEL HEADERS
STAINLESS WORKS 3.5" X PIPE WITH 3.5" MAGNAFLOW MUFFLERS
NX GEMINI TWIN PLATE SYSTEM 100-300 WITH PURGE AND HEATER
MEZIER ELECTRIC WATER PUMP
BMR LOW MOUNT ALT. KIT WITH 130 AMP CAMARO ALT
STOCK 02 CAMARO RAD. AND DUAL FAN SET UP
TRANS :
JW POWER GLIDE WITH STOCK GEAR SET
ULTRA BELL
DEEP PAN
TRANS BRAKE
LOCKING DIPSTICK AND TUBE
CUSTOM MOLY 1350 DRIVESHAFT
TURBO ACTION CHEATA SHIFTER
10" JW NITROUS CONVERTOR
REAR END :
FORD 8.8 REAR
T/A GIRDLE
4.10 GEAR
33 SPL AXLES AND FULL STEEL SPOOL
C CLIP ELIMINATORS
METCO UPPER AND LOWER CONTROL ARMS
TRZ ANTI-ROLL BAR
STRANGE 10 WAY SHOCKS
FRONT END :
QA1 STRUTS WITH COIL OVER KIT
QA1 LOWER A ARMS
AJE K MEMBER
FLAMING RIVER MANUAL RACK AND STEERING SHAFT
BEAR BUMP STEER KIT
CASTER CAMBER PLATERS
WHEELS :
HOLE SHOT HOLE STAR
15X3.5 FRONT WITH RADIAL STREET TIRES
15X8 REAR WITH 28X9 MT SLICKS
FUEL SYSTEM :
10 GAL ALUM. CELL
BG 220 HR PUMP AND REG
-8 FEED -10 RETURN LINES ALL BRAIDED STEEL
Price is 16,000.00 It will have a freshened up engine upon purchase.
Car is in the tampa,Fl area.
here's a video from Bradenton Motorsports Park
http://www.youtube.com/watch?v=y1Y61kie7DI
