Lifted 2001 Jeep Cherokee 4Door
Year: 2001
Make: Jeep
Model: Cherokee
Price: $7800
Mileage: 5
Private or Dealer Listing: Private Listing
Location (State): NH
Color: Black
Transmission: Automatic
Drivetrain: 4WD & AWD
LS Engine?: Car has other engine
4.5L Stroker I-6 with all new sensors, new coils, new 38lb injectors, K&N FIPK, stainless header - goes like heck. 250+ HP -
AW4 - 4 speed automatic transmission
NP231 with Tera slip yoke eliminator and new drive shaft.
HP 30 front (swapped in) Detroit LSD, HD diff cover, 4.10s - all new brakes, bearings and ball joints
Ford 8.8 with Detroit, new4.10 gears, HD diff cover, new bearings and seals, all new brakes and e-brake cables
Body doesn't have a spec of rot. Paint's decent
New rear BDS 5.5 springs
Front suspension is long armed with new radius arms and adjustable bump stops, new Clayton front coils, new track bar bushings and rod end. Disconnects on the sway bar and adjustable bump stops allow any sort of adjustment and max articulation.
ARB front bumper with a Superwinch EP9K
Tires are 33" Trxxus MT's on 15" D ports.
I have a skid plate for the gas tank and receiver hitch that hasn't been installed.
This truck is unstoppable in any weather and most trails you can get a tire on. The entire drive train, brakes and suspension has been re-worked to provide more power and more reliability. Interior is very clean, has a Sony head unit with after market speakers. Heat and AC works very well.
Trade for a complete twin turbo set up for my LS3 in my 71 GMC C15 or a LS1 powered TA/Camaro.
You may want more room than your car has today, you may want better all weather capability or you may want to go four wheeling.
There is literally less than 5K miles on the entire drive train. I wouldn't hesitate to drive this any where.
check out the formula on my fquick and tell me what you think about a trade.......fresh t-56 and ls7 clutch in it with 157k on the odo and too many mods to list
http://www.fquick.com/sprung_monkey
