fairmont roller 20K miles, loaded! setup for LSx!!!
Year: 1981
Make: Ford
Model: Fairmont
Price: $5000
Mileage: 20900
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Green
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
just over 20K miles on original body.
car was found as an original one owner car sitting in a garage in north carolina. seller bought to resale, now converted to street/strip car.
original everything on the body. painted on pin stripe!
no rot, no notable rust for a 30 year old car. only body damage is a small raised dent in the hood. no heat or a/c. silver is faded off the "ford" and "fairmont" emblems on rear trunk lid. car has partial mini tub to maintain factory appearance.
aluminum bumpers, all trim in tact. passenger side mirror delete. factory radio and antenna delete. this car is not show quality, but is in EXCELLENT condition. this is patina from the 80's. its a beatiful ride!!!
lights function. all original glass.
wheel vintiques fr500 magnum wheels front and rear. hoosier 28x10 out back. 27" tires up front.
partial 1 3/4 chromemoly TIG welded rollcage. will not certify in current condition(obvious) main hoop, hoop to trans tunnel braces and rear down bars. car setup as grudge car or sleeper. true grandmas car. comes with hand quilted doyle for both headrests and rear deck.
interior is all stock, minus hurst magnum grip shifter, autometer 5" tach with shift light, water temp and trans temp gauges.
has working factory seatbelts.
underhood has everything but a battery. drop your motor and tranny in and go racing!!!!
car is setup for LS motor and powerglide tranny. mounts and crossmember included.
MSD 6LS box mounted. harness included. tranny lines, fuel lines, huge griffen radiator, permacool tranny cooler. voltage gauge under hood. this car has run 3 classes and can run back to back all night without overheating. whole car wired. comes with 1 3/4 long tube headers and full exhaust with 6 mufflers. 4 bullets and 2 oval ultraflos. car was dead nuts quiet for 600hp.
UPR caster camber mounts. UPR k member modified for LS use. UPR a arms. k member has been dropped to allow clearance of super victor under a stock hood.
strange struts and shocks with coilovers front and back. holley blue fuel pump. 8.8 with 33 spline axles, c clip eliminators and spool. rear aluminum cover. double adjustable UPR uppers. single adjustable UPR lowers. 5 lug conversion with aerospace brakes front and rear. strange style manual master clyinder. factory manual rack.
car has won back to back championships and TWO wallys. car is deadly consistant and has won MANY footbrake races. leaves strait as an arrow.
car weighed 2720# with an all aluminum 402 LS2 and has ran as fast as 6.20's 1/8 mile.
drop your drivetrain in and turn the key over! this is as complete of a roller as you will find.
undercarriage pics taken are of factory drivetrain.
asking 5,000.00
located in navarre florida 32566
![](https://i102.photobucket.com/albums/m108/stage20/DSCN0097.jpg)
![](https://i102.photobucket.com/albums/m108/stage20/DSCN0096.jpg)
![](https://i102.photobucket.com/albums/m108/stage20/DSCN0095.jpg)
![](https://i102.photobucket.com/albums/m108/stage20/DSCN0092.jpg)
![](https://i102.photobucket.com/albums/m108/stage20/dgsfdgsdg.jpg)
![](https://i102.photobucket.com/albums/m108/stage20/DSCN0098.jpg)
![](https://i102.photobucket.com/albums/m108/stage20/005-1.jpg)
![](https://i102.photobucket.com/albums/m108/stage20/003-2.jpg)
![](https://i102.photobucket.com/albums/m108/stage20/021-1.jpg)
