99 z28 cam,stall $6000 OBO
Year: 1999
Make: Chevrolet
Model: Camaro
Price: $6500
Mileage: 197000
Private or Dealer Listing: Private Listing
Location (State): GA
Color: White
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
tsp 228/228 .588/.588 112lsa reverse split camshaft
comp cams valve springs
Midwest 3800 stall converter with Hd lockup
transmission cooler
lid with k&N
True dual exhaust with X pipe, glasspacks, and dumps before the axle
stainless steel longtube headers ( collectors bolt up )
front seats are trans am seats leather graphite
The dash pad was just replaced a month ago with gm part 100% perfect.
Front tires are kumho ecsta 711s with 1,000 miles on them
Rear tires are nitto drag radials 245/50/16 with same mileage on them 1,000 with only one heat up done to them
has small leak from oil pan gasket. nothing major
car has the y3f appearance package
all mods done in last 6months
stock 3.23 gears with small amount off whine only on highway
if car sells for 6k i have innovate wideband o2 sensor with gauge, dual gauge pod for pillar, Nitrous bottle,Bottle bracket, if i can find them i have nitrous solenoid, bottle warmer, wot switch, some nitrous lines, basically have everything but fuel solenoid and the long line to bottle if i can find it all
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
The car has the usual imperfections for the age.. small things in interior need to be done.. and the front end needs to be repainted. Car has no catalytic converters, and will not pass a visual inspection. no codes thrown on dash has mail order tune
A/C and heat both work excellent.. the A/c compressor was just replaced less than a year ago. Brand new battery and alternator i replaced just in case since it was a daily driver
