Real clean 1990 Mustang LX hatch 5.0 5speed
Year: 1990
Make: Ford
Model: Mustang
Price: $5900
Mileage: 105000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
Specs:
Comp cam (e-cam Equivalent)
1.6 roller rockers
BBK Cold air intake
Bullet race mufflers
Holley EGR delete plate Stock mid-pipe with cats
Lowered with Eibach Drag rear springs
Sony radio
Clean black Ponies with Kumho Tires
2002 GT front seats dark charcoal leather w/power
2in Cowl Hood
KYB front struts
KYB rear shocks
Firewall adjuster & quadrant
Adjustable clutch cable
Working Map light
Doors open and close like new
Power Windows work excellent
Trans shifts smooth
Hatch struts work
No leaks
No smoking
No overheating
Tagged and Inspected
New Parts:
OEM Clutch, Pressure Plate, Throw-out Bearing, Pilot Bearing
Flywheel
Trans Fluid
Driveshaft Bolts
Motor Mounts
Power Steering rack
Power Steering fluid
Rack Bushings
Outer & Inner tie rods
Outer & Inner wheel bearings & seals
Brake Rotors
Brake Pads
Motorcraft Spark Plugs
MSD Plug Wires
Temp Sensor
Oxygen Sensors
Intake Air Charge Temp Sensor
MAF
Fuel Pressure gauge
Fuel Pressure regulator
Water Pump
Thermostat 170
New Gaskets, Valve Cover, Intake Manifold upper and lower, Exhaust manifold, Oil pan, Timing cover, Rear main, Water pump, Thermostat, Throttle body, Distributor, IAC,
Comp Cams double roller timing chain and gears
Guide Plates
Head lights & Housing
AC Accumulator
AC Condenser
AC Evaporator
AC Fluid line
AC Pressure line
AC Return line
AC service
Serpentine Belt
Oil & Filter
FRPP negative battery cable assembly
Fresh Paint on everything under the hood
Alignment
Wheel balanced
Speedometer gear
Gauge assembly
Passenger Arm rest pad on back order
Asking 5900.00 obo
Call Jason 254-681-7234
![](http://i12.photobucket.com/albums/a237/03svtcobra/IMG_1327.jpg)
![](http://i12.photobucket.com/albums/a237/03svtcobra/IMG_1326.jpg)
![](http://i12.photobucket.com/albums/a237/03svtcobra/IMG_1325.jpg)
![](http://i12.photobucket.com/albums/a237/03svtcobra/IMG_1324.jpg)
![](http://i12.photobucket.com/albums/a237/03svtcobra/IMG_1323.jpg)
![](http://i12.photobucket.com/albums/a237/03svtcobra/IMG_1322.jpg)
![](http://i12.photobucket.com/albums/a237/03svtcobra/90%20LX/IMG_1336.jpg)
![](http://i12.photobucket.com/albums/a237/03svtcobra/90%20LX/IMG_1335.jpg)
![](http://i12.photobucket.com/albums/a237/03svtcobra/90%20LX/IMG_1334.jpg)
![](http://i12.photobucket.com/albums/a237/03svtcobra/90%20LX/IMG_1333.jpg)
![](http://i12.photobucket.com/albums/a237/03svtcobra/90%20LX/IMG_1331.jpg)
![](http://i12.photobucket.com/albums/a237/03svtcobra/90%20LX/IMG_1327.jpg)
![](http://i12.photobucket.com/albums/a237/03svtcobra/90%20LX/IMG_1321.jpg)
