92 Mustang LX with turbocharged LS motor
Year: 1992
Make: Ford
Model: Mustang
Price: $25000
Mileage: 99999
Private or Dealer Listing: Private Listing
Location (State): IN
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
CHASSIS
-minitubbed
-Wolfe CM 10 point w/ extra bars to strut towers and frame
-Subframe connectors
-Lower Battleboxes with bars to cage
-upper torque boxes welded
-PA k-member
-PA 1" shorter a-arms
-Strange adj. front struts with Strange 175 lb. springs
-QA1 caster/camber plates
-Wolfe DA uppers with spherical bearings
-PA Double adj. offset lowers
-AFCO Double adj. Big Gun coilovers
-UPR anti-roll bar
-8.8 narrowed 3" each side, welded and braced with 9" ends
-FMS 3.27 gear
-Moser 35 spline axles with 5/8 studs and Moser spool
-T/A girdle
-Racecraft LCA brackets moved in 2"
-Billet Specialty Street Lites, 15x12 rear and 15x3.5 front
-Moroso DS2 fronts and 28x10.5 Hoosier stiff sides
-Strange front and rear brakes
-Pinto rack with Racecraft bumpsteer kit
-Stroud parachute with removable mount
-Racecraft strutless wing
-Kirkey prostreet seats
FUEL SYSTEM
-15 gallon cell with sending unit
-Magnafuel EFI 750 pump
-Aeromotive pre and post filters
-Aeromotive pro series regulator
-160 lb. injectors
ENGINE
-iron block 408, new GM block
-Callies Magnum crank
-Callies h-beam rods
-Mahle pistons
-DM Perfromance main girdle
-ARP main studs
-ARP 12 point head studs
-853 head castings, cnc'd
-LS9 head gaskets
-Allstar radiator with 1/2 Moroso overflow in hatch
-Meziere electric water pump with all -16an lines
-Proflow intake
-NW 90mm throttle body
-BS3 with DAI tuned by Jim Moran @ Speed Inc
TURBO
-custon truck manifold kit
-Bullseye Power S480 with race cover
-60mm wastegate
-50mm Tial BOV
-4" thick A2A intercooler
-MSD Boost controller
TRANSMISSION
-TH400
-JW Ultrabell
-TCI RMVB with brake
-B&M deep aluminum pan
-B&M supercooler with fan under car
-B&M supercooler in aluminum tank in hatch for ice
-B&M Prostick with magnum grip
-custom Ultimate Converter Concepts converter
-TCI flexplate
everything was bought new and car was built less than a year ago.
will give hp and times to serious buyers incase someone wanted to grudge race it or incase i race it before it sells.
very streetable and runs on e85. drive all over the place
located in hammond, indiana
$25k FIRM
![](http://i27.photobucket.com/albums/c165/shady93z/IMG_20110501_094548.jpg)
![](http://i27.photobucket.com/albums/c165/shady93z/IMG_20110501_094625.jpg)
![](http://i27.photobucket.com/albums/c165/shady93z/IMG_20110313_140310.jpg)
![](http://i27.photobucket.com/albums/c165/shady93z/IMG_20110305_001527.jpg)
![](http://i27.photobucket.com/albums/c165/shady93z/IMG_20110223_165855.jpg)
![](http://i27.photobucket.com/albums/c165/shady93z/DSC07496.jpg)
![](http://i27.photobucket.com/albums/c165/shady93z/DSC07492.jpg)
videos from last year
http://www.youtube.com/watch?v=YFwVTX0f9D4&NR=1
http://www.youtube.com/watch?v=PTUrJuS83ZI&NR=1
http://www.youtube.com/watch?v=GPRNRcY-cOE&NR=1
http://www.youtube.com/watch?v=LF-dlHcu7Y4
videos from this year
http://www.youtube.com/watch?v=urYfiWKLpSc
http://www.youtube.com/watch?v=cfI3rJ9DIzw
http://www.youtube.com/watch?v=mulS9...eature=related
