feeler..00 mustang gt ( temi clone w/ls1 swap)
Year: 2000
Make: Ford
Model: Mustang
Price: $10000
Mileage: 2000
Private or Dealer Listing: Private Listing
Location (State): SC
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
ive owned car for little over three years now and the car started out as a gt with the 4.6 which didnt last long 7 months lol,,,
the car was white in the begining and has been painted with ppg black paint, all jams, doors and trunk where done under hood is flat,
now to the goods
has 373c.i stoker kit ( good to 1000hp) from coast high perf
cnc ported stage 2 ls6 heads with upgraded valve springs and ss valves
ngk plugs
powerbond underdrive crank pully
hardened push rods
cometic MLS head gaskets
new ls2 timing chain
ms4 cam with new comp cam lifters
ported ls6 oil pump
ls6 intake
30lb inj frpp
arp bolts threw out whole motor
camaro radiator and elec fans
stand alone harness from psi
new th350 manuel valve bodywith built to handle anything
new heavy duty yoke with new tube for drive shaft
hurst shifter
4in carbon fiber vis hood painted
04 cobra front bumper
v6 rear bumper(no exhaust cut outs)
aje k member
bbk subframe conectors
eibach sport springs
granitelli upper and lower control arms both adj and lower has hieght adj
255lph walbro
ford racing 410 gears
auburn locker
has weld drag lites 10in rear, w/ 325/50 mickeys dr
front 3.5in with skinnys
im sure im forgetting some stuff,
has all auto meter gauges, 4 guages in cluster and 3 on pilar
car is just about finished only thing left is finish wiring(power, ground, and gauges) and headers and exhaust,and im deploying in may and dont want to have it while im deployed so i can just save up money for the c6 i want when i get back
the car is currently located in hampton va but by the end of the month will be in gaston sc at my dads bc im moving out of my house and all stuff goin there before deployment,,
if no intrest im gonna just finish it and ill put it back up when its done ,
8035873958 names jeff, call or txt for more info or pics, thankx
So u have no time to do the wiring? Ita juat power ground and gauges? Also will stock headers fit it or do u need a custom set made? Do u need hugger headers for them to fit? Or do u think any aftermarket header will bolt up and have clearance?
the headers are only made by dynatech and kooks they are only headers that will work bc of the steering shaft, ive seen ppl take 5.0 sbf headers and cut the flanges off were they bolt to block and weld ls flanges to them for the cheaper way out, wiring isnt hard is just were you want to mount the computer, and guages just need some sending units, ive just lost intrest in it at this point and running out of time were im at..
