FS: 99 TA with custom turbo kit, 9", glide
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $0
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Red
LS Engine?: Car has LS engine
The car is in good condition, been garaged.
Motor:
HKE 408 with Callies internals and Wiseco pistons, 9.5:1 CR
Custom cam from Frankenstein heads, solid roller
Crower solid roller lifters
Trend .135 wall pushrods, two spares also.
ETP 255 heads, ported by Frankenstein heads. Flowed up to 370@.800” These have PAC coated valve springs, Manley SS intake vavles, Iconel ex valves
Jesel Mohawk shaft rockers, spare rocker too
GMPP intake, ported by Yelvi with further modifications
Wilson Elbow
Wilson 105mm TB
Turbo Kit:
Custom turbo kit by SQR, how side is coated with two Tial 44mm valves
Cold side is all aluminum with a custom air to air intercooler
BW SX50088 turbo
Its is all v-banded
Drive-train:
Neal Racing Powerglide with 1.80 gear.
Neal Chance bolt together converter
Jerry Bickell chromemoly drive shaft
Ford 9” with back brace, built by Moser. Moser 35 spline gun drilled axles, spool, 3:55 gears
Rear brakes are Aerospace dual calipers
Front brakes are stock
PA Racing K-member and a-arms
Custom Fuel cell/water tank
Custom trans cooler mounted in trunk, all AN lines
Weldon 2035 fuel pump with Weldon filter. All fuel lines are AN.
160#/hr injectors, Wilson Fuel rails
Interior of the car has remained stock, stock front seats, stock back seats. Wolfe 10pt cage Center console looks stock
QA1 adjustable shock/struts all around
Wolfe torque arm, lower control arms and above the rear double sway bar.
BS3 computer system with all the upgrades, external crank sensor, DS sensor, G-meter.
VFN Dzus hood with rails
Car runs on E85, made right at 1000rwhp on 19psi.
$30,000.00 pretty firm. I don’t have to sell, just don’t have the time.
If you want more pics, let me know, I will take some.
Here is a short video too
http://img440.imageshack.us/img440/8691/j1lu.mp4
Car ran a 5.72@123 with a 1.40 60' on 275DR on 16psi, ramping the boost in real slow.
Thanks
Scott
