1999 Trans Am 25.3 drag radial rolling chassis
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $20000
Mileage: 1
Private or Dealer Listing: Private Listing
Location (State): MD
Color: Gray
Drivetrain: Rear Wheel Drive
PRICE IS DEFINATELY NEGOTIABLE
What I'm selling at this point is the rolling chassis only: Includes all of the following:
Certified 25.3 chassis (cert date 7/10)
Trakstar pro 15x10 rear wheels with nearly new 315/60/15 M/T drag radials
Trakstar pro 15x4 front wheels with M/T front runners
strange front brakes
wilwood dual rear caliper rear brakes
Joe Van Overbeek carbon fiber rear wing
Dual Shroud Prostock Parachutes
PST 3" moly driveshaft
transmission crossmember for Powerglide
Moser 9" rear with back brace, aluminum center, 35-spline spool and axles, 5/8" wheel studs, 3.40 pro gears
AFCO scirroco radiator + custom aluminum expansion tank
Meziere 55gpm remote water pump
BMR front Kmember
Glasstek fiberglass dashboard with RACEPAK dash
Vacuum, trans temp and oil temp gauges in dash (center vents)
Kirkey Prodrag seat
rear battery box with 16V battery
5gal icewater tank with internal bilge pump
wheelie bars
Custom removable front end with VFN 5" sloped cowl hood
3/16" "drop in" lexan front window
power windows still operational
B&M shifter
carbon fiber panel to mount EGT and BS3 (EGT system and BS3 not included)
custom chromemoly steering column
AFCO double adjustable shocks on all 4 corners (fronts are 1yr old, rears were rebuilt last year)
Safecraft 10lb fire suppression system
MADMAN suspension limiters
custom chromemoly torque arm
Wolfe chromemoly Lower control arms
custom chromemoly panhard rod
Wolfe minitubs
Car has been mid 7.70s and nearly 190mph in the 1/4
Tons of detailed pictures shown in my build thread.
https://ls1tech.com/forums/forced-in...ld-thread.html
Will include the matching EZGO gas golf cart + retractable strap for additional 3K
