93 Camaro roller set up for 275 or 295 drag radial
Year: 1993
Make: Chevrolet
Model: Camaro
Price: $10500
Mileage: 1
Private or Dealer Listing: Private Listing
Location (State): MO
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
-clear Missouri title, I have owned the car since '05
-chrome moly cage certified to 8.50 when it was installed in '08
-Moser 12 bolt, 3.73, 33 spline gundrilled axles, spool
-Denny's nitrous driveshaft
-Glasstek 4" cowl hood, bolt on
-QA1 struts, 3 way Comp Eng rear shocks, BMR adj anti roll bar setup, BMR K member, Flaming River manual rack, tubular control arms (front), tubular LCA (rear), BMR Xtreme torque arm (brand new), BMR crossmember for th-350 or glide, BMR frame connectors, additional x brace underneath installed by Midwest Chassis and Accessories in Chaffee MO
-Autometer tach with light, Autometer fuel pressure gauge mounted on cowl, Equus oil pressure and coolant temp gauge installed in dash
-Has factory seats in the car but comes with 2 Kirkey seats and covers
-comes with glide with 1.96 low, turbo spline input shaft, factory case, built by Coan
-Holeshot stars with M/T Sportsman Pro fronts, Hoosier 275 drag radials on back with 2 passes on them
-factory radiator with 16" electric fan on front
-Nasty Performance aluminum fuel cell (bolts in factory tank position)
-NEW Magnafuel ProStar 500 pump, -10 fuel filter with removable element, -10 line to Aeromotive regulator mounted on firewall
-standalone nitrous fuel system in front passenger side, consists of Jaz 1 gallon cell, Russell filter, Holley blue pump
-repainted factory black in '08, good factory glass, comes with 2 extra doors with manual crank windows, there are some cracks and peeling on the plastic nose, but everything else is good
-I had a carbed 6.0 based engine in this car and it will include the motor mounts if you want to stay with LS style engine
-I can send more pics by email or text
-$10,500
-call or text 573- 450- 8941
![](http://i237.photobucket.com/albums/ff89/hurstoldsracer/Camaro/IMG_00741.jpg)
![](http://i237.photobucket.com/albums/ff89/hurstoldsracer/Camaro/photobucket-26378-1350000221322.jpg)
![](http://i237.photobucket.com/albums/ff89/hurstoldsracer/Camaro/photobucket-28496-1350000023149.jpg)
![](http://i237.photobucket.com/albums/ff89/hurstoldsracer/Camaro/photobucket-28797-1350000199920.jpg)
Your choice of transmissions with the car. I have the glide that is in the listing above, or a TH350 with TCI hardened sprag, Kolene clutches and steels, deep aluminum Stef's pan. The glide has a transbrake, the TH350 does not.
I can keep the Kirkey seats and transmission and sell the car for $9000 obo. The car has 295/65/15 Hoosier drag radials in the picture above. It has 275/60/15 on it now.
