Supercharged 2006 Trailblazer SS
Year: 2006
Make: Chevrolet
Model: TrailBlazer
Price: $15000
Mileage: 94000
Private or Dealer Listing: Private Listing
Location (State): KS
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Price: $19,000 OBO - Would consider 14-15k cash with a 4-6k trade
Year: 2006
Make: Chevy
Model: Trailblazer SS
Mileage: ~94k
Title Status: Clean
Transmission: Built 4l70E
Drivetrain: 2WD
06 Superior blue 2wd Trailblazer SS LT - (3SS) Loaded, leather, bose, navigation, rear dvd ~94k miles (Transmission has less than 4000 miles on it, heads, cam, lifters, timing chain all brand new with less than 1500 miles)
This truck is my baby, hate to see her go! Supercharged LS2 with ported heads, custom cam and all the right goodies. Built transmission with more billet parts than you can shake a stick at! Beautiful color with nice accents but nothing over the top, always a head turner! I can take more pictures for anyone interested. I drive it when the weather is nice and am still working on some of the little projects that need to be taken care of.
Love this truck. I'll include any odds and ends I have laying around, (tons of stock parts) along with my set of drag wheels (steel spares with tires on the front and aluminum 17" TB wheels with slicks for the back. Slicks don't have much life left.
Got a couple runs in at heartland the other night. Ran a 12.07 @ 115 with a 1.8 60' It was 92* and a DA around 3k I think. Lots of room for improvement with good tune.
Year: 2006
Make: Chevy
Mileage: ~94k
Title Status: Clean
Drivetrain: 2WD
![](http://i21.photobucket.com/albums/b298/98onyxss/TBSS%20Build/20130605_093902_zps19dc490a.jpg)
Mod List
(Putting some guesstimates on the prices next to the parts just for fun)
Lowered 2” Front belltech struts, bag adjust rear
DJM modified A-arms (stock height) $350
Addco sway bars front and rear $300
LC32 cross members $300
LC32 Driveshaft Loop $120
Simple engineering Frame stiffening plate (Powdercoated) $200
Stealth 340 fuel pump $100
Magnavolt (Uprgraded wire from magnavolt to pump) $100
Built transmission with: $3000
Billet Input Shaft
Billet Output Shaft
Billet pump rotor
Billet circle d apply servo
Sonnax smart tech input drum
Wide 2-4 drum
Wide 2-4 band
Billet sonnax 2-3 servo
Billet sonnax 3-4 servo
5 pinion planetary
TCI aluminum deep pan
Circle d triple disk billet 3600 stall converter $1200
Reactor billet flexplate $350
PCM Forless Standalone trans cooler $100
Stock block
Katech rod bolts $100
c-6 rear sump oil pan $200
ported 317 heads $400
dual valve springs From FMS with TI retainers and locks $250
rocker trunion upgrade $100
hardened pushrods $100
LS7 Lifters $80
custom blower cam From LT1Z $400
c5r timing chain $100
billet timing gears $100
ls6 oil pump $100
edelbrock proflow intake $600
ported ls7 throttle body $100
60lb injectors $300
Ls7 maf $100
Custom house of boost blower brackets with 8 rib dedicated drive $1200
Vortech y-trim race cut straight gears $3000
Vortech maxflow bypass valve $200
HOB Intercooler w/ 3” ends $250
Methanol kit with devils own large tank $300
07+ water pump w/ 160 t-stat
Carbon fiber scotts hood $1400
Baer decelarotors with hawk lts pads $1200
Stainless steel braided brake lines
Wideband LC1
Guage pillar pod with fuel pressure, trans temp, and boost/vacuum
Trans pressure guage
Stainless works long tube headers, 3” dual exhaust to magnaflow 3.5” dual in/out x-flow muffler $600
TBM Blank valence insert painted to match $400
Various LED lights throughout the truck inside and outside
Brand new HID bulbs and Ballasts w/ DRL Killer and Quad headlight setup.
LS1 Efans with PCMforless brackets/wiring
Other random **** I cant remember. So just the estimates on the prices (which is low and doesn’t include nearly everything in this truck)….$17,700!!!! In modifications alone!!!!
No AC ---AC lines need to be made (AC Compressor, Evaporator, condenser are all there and good. Just need to go down to the local hydraulics shop and have some new lines crimped up and charge the system)
Needs little minor projects here and there but nothing major.
$19k Truck retails for 17k clean. Im saying the truck is worth 14k and you are getting all the mods for 5k. Tthere are over 17k in mods here easily) This is a massive steal, even with the little stuff that needs work.
Billet Input Shaft
Billet Output Shaft
Billet pump rotor
Wide 2-4 drum
Wide 2-4 band
5 pinion planetary
Stock block
LS7 Lifters $80
ls6 oil pump $100
60lb injectors $300
Ls7 maf $100
Wideband LC1
