1989 r3500 dually on 24in semi's
Year: 1989
Make: Chevrolet
Model: Silverado 3500
Price: $10000
Mileage: 98500
Private or Dealer Listing: Private Listing
Location (State): TN
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
98,xxx original miles have auto check to prove this. Also no wrecks or any other type of branded title. Passed Virginia inspection this year.
454 big block TBI (runs perfect)
Turbo 400 transmission (shifts like new)
dana 70hd (no noises at all)
24.5in peterbuilts milled to 24s with almost new tires on them. (Less than 1000 miles on them)
Wheels just polished
Brand new centers and spikes
Centramatic wheel balancing rings front and rear
True duals flowmaster exhaust
Ran seafoam thru 2 tanks of fuel
Ran seafoam in crankcase to clean it
Carbon cleaned the combustion chamber with seafoam
comes with:
new 6/8 western chassis drop kit... spindles, springs, and flip kit
Narrower axle shafts for rear
New moog upper control arm shafts
New moog lower control arm shafts
new moog inner tie rod ends
new moog outer tie rod ends
new moog pitman arm
new moog idler arm
new moog upper ball joints
new moog lower ball joints
new moog tie rod adjusters
new energy suspension sway bar bushings
new energy suspension tie rod end boots
new rough country steering stabilizer kit
new rotors
new wagner severe duty pads (front)
new rubber brake lines (front)
New rubber brake line (rear)
new national inner wheel bearings
new national outer wheel bearing
new national wheel seals
new brake calipers
new energy suspension cab mounts
new energy suspension motor mounts
new energy suspension transmission mount
new msd rotor cap and button
new msd performance coil
New acdelco plugs
New puralator fuel filter
new taylor stainless braided plug wires
new gm performance valve covers
new goodmark rollpan
New 180 thermostat and gasket
New drop shocks for front
Transgo shift kit
6 bottles of royal purple ps fluid
4 bottles of royal purple diff fluid
3 or 4 tubes of royal purple grease
6 quarts of ATF
Probably more I'm forgetting
This is one of the most complete trucks I have owned if it came on it from the factory it's still there. The interior is in really good shape also. This truck has lived a good life it was well taken care of. The body is straight as an arrow the primer is because the original paint was beginning to fade and didn't want a lot of flash rust .
Feel free to text or call.... 423-248-9931
More pics here
http://www.mautofied.com/1989-Chevro...ing/100591683/
