FS: 1993 Mustang LX ROLLER, 53k original mile LS Swap Ready!!!
Year: 1993
Make: Ford
Model: Mustang
Price: $3900
Mileage: 53000
Private or Dealer Listing: Private Listing
Location (State): OH
Color: Green
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
513-315-6583 call or text
-Factory Bright Calypso Green car
-Team Z front and rear suspension, all new or has less than 1,000 miles
-PA Tubular K member for LS swap
-Strange 10 ways all around with Strange coilovers, 12” 175lb springs
-Cobra brakes up front with Maximum motorsports brake lines, 93 cobra master cylinder, MM 3-2 port conversion, Brembo slotted rotors
-Brand new Flaming River manual rack with brand new, fully welded Maximum Motorsports steering shaft. Welding done by Rob at Rogue.
-MM drill through spindle bump steer kit
-94/95 spindles with new Timken hubs
-Built 8.8 by Rob at Rogue Race Cars in Williamsburg, Ohio. Welded axle tubes, 9” Moser ends welded on in a jig, entire axle housing POR-15’d, customer Moser 31 spline axles, Eaton 31 spline diff, 3.27 gears and Wilwood 4 piston 11” disc brake with multi piece rotors and custom powdercoated rear diff cover by Kenny at Killer Koatings
-FMS B rear springs
-MM full length subframes welded in by Rob at Rogue
-MM pinion snubber
-Mint, factory 93 opal gray interior with brand new carpet
-Battery relocated to the rear in nice alum box
-UPR C/C plates
-Smoked headlights and tails
-Steeda front sway bar
-Boss inc hood, brand new, unpainted, no holes drilled whatsoever
-Brand new green Raptor shift light
-Stock fuel lines, no fuel tank
-98 Cobra wheels on poopy rubber
-Any modification that is bolted onto the car was replaced with grade 8 hardware
-Car was COMPLETELY disassembled for paint years ago. All trim removed and either replaced with new or full preppy and re-painted using the LRS trim black to match OEM color
-Folder full of receipts with the different things I’ve bought for the car over the years
-Clean and clear Ohio title in MY name
It would be very tough to find a car in this condition especially with the original mileage this car has. I have personally owned this car for 11 years! The paint and body is NOT 100% perfect, but is straighter and cleaner than probably 98% of foxes out there.
RACE STARS ARE NOT INCLUDED. Car is rolling on OEM 1998 Cobra wheels.
$3900
![](http://i446.photobucket.com/albums/qq188/bad306lx/93%20Mustang/IMG_9206.jpg)
![](http://i446.photobucket.com/albums/qq188/bad306lx/93%20Mustang/IMG_5762.jpg)
![](http://i446.photobucket.com/albums/qq188/bad306lx/93%20Mustang/IMG_4578.jpg)
![](http://i446.photobucket.com/albums/qq188/bad306lx/93%20Mustang/IMG_2542.jpg)
Driver side rear frame rail:
![](http://i446.photobucket.com/albums/qq188/bad306lx/IMG_9441_zpsf8a9d736.jpg)
![](http://i446.photobucket.com/albums/qq188/bad306lx/IMG_8832_zps2c3a7e10.jpg)
![](http://i446.photobucket.com/albums/qq188/bad306lx/IMG_8556_zpsf24080b4.jpg)
Right rear suspension and brakes. FMS B springs now installed:
![](http://i446.photobucket.com/albums/qq188/bad306lx/IMG_8542_zps60a1b6f6.jpg)
![](http://i446.photobucket.com/albums/qq188/bad306lx/IMG_8380_zps76c9d454.jpg)
![](http://i446.photobucket.com/albums/qq188/bad306lx/IMG_7773_zps6e5e1c93.jpg)
Stock fuel lines still in the car as well as new Wix fuel filter:
![](http://i446.photobucket.com/albums/qq188/bad306lx/IMG_0643_zps206d597b.jpg)
Fuel tank straps, harness and filler neck still in the car:
![](http://i446.photobucket.com/albums/qq188/bad306lx/IMG_3866_zps852b0bc1.jpg)
Rear axle with PC'd diff cover, classic tube stainless pre bent brake lines, etc:
![](http://i446.photobucket.com/albums/qq188/bad306lx/IMG_8156_zpsd75aa52d.jpg)
513-315-6583 call or text.
Underhood / frame rail / wire tuck shots. I forgot how dang clean this thing is under there. Quiklx Joe performed the wire tuck on the car. The frame rails have never had any rust repair, this is all original (was repainted the factory color with cryl when I first got it, but just scuffed and sprayed):
![](http://i446.photobucket.com/albums/qq188/bad306lx/93%20Mustang/IMG_8292_zps67b6d140.jpg)
![](http://i446.photobucket.com/albums/qq188/bad306lx/93%20Mustang/IMG_7418_zps056eafc2.jpg)
![](http://i446.photobucket.com/albums/qq188/bad306lx/93%20Mustang/IMG_6392_zps6680e636.jpg)
![](http://i446.photobucket.com/albums/qq188/bad306lx/93%20Mustang/IMG_1295_zpsa420a1f6.jpg)
Brakes / front suspension (red cable is roughly routed power wire from battery relocation):
![](http://i446.photobucket.com/albums/qq188/bad306lx/93%20Mustang/IMG_0359_zps66dcb626.jpg)
![](http://i446.photobucket.com/albums/qq188/bad306lx/93%20Mustang/IMG_4552_zps7ae62325.jpg)
Interior:
![](http://i446.photobucket.com/albums/qq188/bad306lx/93%20Mustang/IMG_3941_zps2fb0361d.jpg)
Battery relocation:
Interior:
Battery relocation:
![](http://i446.photobucket.com/albums/qq188/bad306lx/93%20Mustang/IMG_7842_zps3604cf52.jpg)
Now on ebay:
http://www.ebay.com/itm/Ford-Mustang-LX-1993-Ford-Mustang-LX-Hatchback-Project-Complete-Roller-53k-Original-miles-/201071272373?forcerrptr=true&hash=item2ed0c821b5&item=201071272373&pt=US_Cars_Trucks
